More than one phone number format?
Thread begun 7/31/2009 11:10 pm by Groshko | Last modified 8/05/2009 4:50 pm by Jason Byrnes | 13818 views | 7 replies |
Groshko
Hello,
In the SpryValidationTextField.js file around line 425 there is the option to have a custom phone number format. No mater what I change the 'phone_custom' pattern to, my form still doesn't identify the format. Any ideas?
Many thanks,
G
'phone_number': {
formats: {
//AUST phone number; 10 digits
'phone_us': {
pattern:'(00) 0000 0000'
'phone_custom': {
pattern:'(00) 00000000'
In the property inspector for the phone number spry text field, make sure that:
1) You have set the Type to Phone Number.
2) Select the Custom or US/Canada format
3) Checked the option to validate on Blur
4) Checked the required option
5) checked the Enforce Pattern Option.
Groshko
Thank-you, but still a little uncertain in some areas.
1) Are you sure the Type needs to be "Phone Number". Another example i saw the type was TEXT?
2) I don't see where the option to select "Custom/US" is. I can see this reference in the SpryValidationTextField.js, but don't know if changes are needed here?
3) Option to Validate on Blur in ok.
4) Required option is ok.
5) I don't know how to enforce this option.
Below are some code sippets i think are relvantant. Hopefully you may be able to assist me.
Many Thanks,
G
------------top of contact form--------------
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Contact_Name"]))?$_POST["Contact_Name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateEM(((isset($_POST["Email_address"]))?$_POST["Email_address"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Comments"]))?$_POST["Comments"]:"") . "",true,3);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,4);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,5);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,6);
$WAFV_Errors .= WAValidateRX(((isset($_POST["seconddblock"]))?$_POST["seconddblock"]:"") . "","/^$/i",false,7);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Phone"]))?$_POST["Phone"]:"") . "",true,8);
$WAFV_Errors .= WAValidatePN(((isset($_POST["mobile"]))?$_POST["mobile"]:"") . "",true,false,true,9);
----------middle of contact form-----------
<label for="Phone">Phone:<br>
</label>
<span id="sprytextfield5">
<input name="Phone" type="text" id="Phone" class="inputValue" onblur="if (document.getElementById('phoneServerError')) document.getElementById('phoneNameServerError').st yle.display='none'" value="<?php echo(ValidatedField("contact","Phone Number")) ?>" size="30">
<br><span class="textfieldRequiredMsg">A value is required.</span></span>
<input name="addblock" type="text" id="addblock" style="display:none" value="" />
if (ValidatedField("contact","contact")) {
if ((strpos((",".ValidatedField("contact","contact"). ","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span id="nameServerError" class="textfieldServerError">Please provide your phone.</span>
<?php //WAFV_Conditional contact.php contact(1
<br />
<span id="sprytextfield6">
<label>Mobile:<br>
<input name="Mobile" type="text" id="Mobile" size="30">
</label>
<br>
<br>
--------bottom of contact form----------
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "none", {validateOn:["blur"]});
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2", "email", {validateOn:["blur"]});
var sprytextarea1 = new Spry.Widget.ValidationTextarea("sprytextarea1", {validateOn:["blur"]});
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur"], minChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>, maxChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>});
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "none", {validateOn:["blur"]});
var sprytextfield5 = new Spry.Widget.ValidationTextField("sprytextfield5", "phone_number", {validateOn:["blur"]});
var sprytextfield6 = new Spry.Widget.ValidationTextField("sprytextfield6", "mobile_number", {validateOn:["blur"]});
</script>
---------phone refference on SpryValidationTextField.js--------
'phone_number': {
formats: {
//US phone number; 10 digits
'phone_us': {
'phone_custom': {
'mobile_number': {
formats: {
'phone_us': {
pattern:'0000 000 000'
'phone_custom': {
pattern:'0000 000 0000'
try changing:
to:
var sprytextfield5 = new Spry.Widget.ValidationTextField("sprytextfield5", "phone_number", {validateOn:["blur"], useCharacterMasking:true});
var sprytextfield6 = new Spry.Widget.ValidationTextField("sprytextfield6", "phone_number", {validateOn:["blur"], useCharacterMasking:true});
Groshko
  try changing:
to:
Thank-you. This is coming along nicely.
Hopefully this is my last question.
I have two phone fields, phone and mobile phone.
Both of these fields are required by the user, but I would like the mobile phone not to be a requirement. This field stills need to be a spry, for if somebody does fill this out it follows the mask that is in place. Does anybody know how to set this to "not required"?
Many Thanks Team!
To change the behavior of a spry text field, select the text box in design view. When the text box is selected, you will notice a blue bounding box appear with the wordds "Spry Text Field: sprytextfield<id>" Click this. In the property inspector, you will be ablwe to modify the spry text field behaviors. Uncheck the required option for the mobile phone text field so it will not be required any more.
Groshko
GREAT!!!
Thank-you for your help. I had no idea how to find the property inspector. All makes sense now.
G
Glad to hear it is sorted for you now.
