Apply to existing template
Thread begun 5/01/2012 1:03 pm by CraigR | Last modified 5/02/2012 8:03 am by Ray Borduin | 2985 views | 3 replies |
CraigRBeta Tester
With DA2, I remember being able to use an existing template on which to create pages whilst using the wizard
Is this available in Databridge, I cant find it ?
No, in Data Bridge you have to apply the template after running the wizard.
We decided to remove that feature for two reasons...
1) we want to promote using plugins and themes from framework builder instead of templates to begin with.
2) we can't test on all of the possible templates that are out there and we were running into a lot of issues where the template was causing the wizard to not work properly, and since it isn't any different than adding the template after generating the pages it seemed like added complexity without much benefit.
Jordan
Is there a guide anywhere that would help? I can't seem to add my templates or create and add from framework builder as the templates need to be applied beforehand. Thanks.
I found what the issue is... it doesn't play nice with HTML5.
I don't think it has anything to do with html5. It may have something to do with other settings in your template.
Is there any way you could email me the template you are trying to use so I can reproduce the issue (ray@webassist.com).
I'm assuming you just run the wizard and try to apply that template. That will allow me to determine if it is a bug or not and get it fixed or provide a better explanation.
