Changing Database
Thread begun 7/27/2009 7:09 pm by tirzahm338096 | Last modified 7/29/2009 8:01 am by Ray Borduin | 2770 views | 1 replies |
tirzahm338096
Changing Database
I would like to change some of the product fields within the database and I'm wondering if its as simple as adding and renaming the fields and then making sure i update and add them within the content pages.
I am looking to customize for a bookstore and would like to add a author field and also change ProductSKU to ProductISBN. I also have 4 different languages of books and would like to create a language category as well. How much will i be upsetting the apple cart so to speak with these changes or are they fairly minor? I am a rookie rookie and wondering if I'm being to bold to attempt this. Any help or heads-up would be appreciated.
It isn't terribly bold. It is what the tools are designed to do. Anyone doing something for the first time might run into a learning curve, but really it should be relatively simple.
tim299030
Where are the fields added in the pages?
I am also doing a new site for a book publisher and I need to add fields for Subtitle and Author.
I added both of these to the ps4_products table with no problem but when I added them to the "details.php" file (under <span id="WADAPageTitle"><?php echo str_replace("|","<br />",$row_WADAProducts["ProductName"]); ?></span>) it didn't work.
I'm assuming it didn't work because I didn't add those fields to the recordset or SELECT statement, but I can't figure out where the SELECT statement is that I need to add those two new fields to.
Shouldn't I be able to add those fields to the SELECT statement and then insert the fields in the details.php file?
Yes, that should be all it would take. You should be able to double-click on the Recordset in the server behaviors window to edit the select statement. Did you look in the database and confirm that the fields are getting values?
tim299030
Thanks, Ray. It works now. I always forget about the server behaviors panel and try to add it in the code view -- but I didn't see the recordset in the code. The server behavior window did the trick for me.
