Mega Menus
Thread begun 2/28/2012 3:01 am by fragop363190 | Last modified 2/29/2012 1:04 pm by Jason Byrnes | 5220 views | 3 replies |
fragop363190
Mega Menus
Hello,
i'd like to know if i can add php code withi na CSS Writer subment in order to add dynamic HTML code (div/tables etc), in order to create a Mega Menu.
Has anyone done this using CSS Writer?
you would need to edit the menu code to add the divs and tables into the sub menu li elements.
fragop363190
Do you mean that if i add div tag with html/php code within the sub menu li items, that item will be populated with the full generated html?
Thank you in advance.
yes, thats correct, you'll need to set the width of the submenus to accommodate the extra content too.
