Update page redirect problems
Thread begun 7/21/2009 9:44 am by gbgnyco367794 | Last modified 8/03/2009 10:21 am by Eric Mittman | 3415 views | 4 replies |
gbgnyco367794
I am creating a multiple step process and need an update page to send the sales_id to the next page...I am not very good with php and cant figure out why this will not work....any help?
here is the current code:
// WA Application Builder Update
if (isset($_POST["Update_x"])) // Trigger
$WA_connection = $a;
$WA_table = "sales";
$WA_redirectURL = "contractchoice.php";
$WA_keepQueryString = false;
$WA_indexField = "sales_id";
$WA_fieldNamesStr = "Date_of_funding|Check_Number|Funding_amount|Funding_fee|interest|Investor|Approved_by|Approved|Comments|admifee|delfee|underid";
$WA_fieldValuesStr = "".((isset($_POST["Date_of_funding"]))?$_POST["Date_of_funding"]:"") ."" . "|" . "".((isset($_POST["Check_Number"]))?$_POST["Check_Number"]:"") ."" . "|" . "".((isset($_POST["Funding_amount"]))?$_POST["Funding_amount"]:"") ."" . "|" . "".((isset($_POST["Funding_fee"]))?$_POST["Funding_fee"]:"") ."" . "|" . "".((isset($_POST["interest"]))?$_POST["interest"]:"") ."" . "|" . "".((isset($_POST["Investor"]))?$_POST["Investor"]:"") ."" . "|" . "".((isset($_POST["Approved_by"]))?$_POST["Approved_by"]:"") ."" . "|" . "".((isset($_POST["Approved"]))?$_POST["Approved"]:"") ."" . "|" . "".((isset($_POST["Comments"]))?$_POST["Comments"]:"") ."" . "|" . "".((isset($_POST["admifee"]))?$_POST["admifee"]:"") ."" . "|" . "".((isset($_POST["delfee"]))?$_POST["delfee"]:"") ."" . "|" . "".((isset($_POST["underid"]))?$_POST["underid"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_comparisonStr = " LIKE | LIKE | LIKE | LIKE | LIKE | LIKE | LIKE | LIKE | LIKE | LIKE | LIKE | LIKE ";
$WA_where_fieldValuesStr = "".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_a;
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
I need the redirect to be
$WA_redirectURL = "contractchoice.php?sales_id=<?php echo(rawurlencode($row_WADAsales['sales_id'])) ?>";
$WA_redirectURL = "contractchoice.php?sales_id=".rawurlencode($row_WADAsales['sales_id']);
gbgnyco367794
Thanks...had to take the space out of w ada but it works!!!
danne.polk73888
Can you give example of this for coldfusion?
Can you give an equivalent example in coldfusion?
$WA_redirectURL = "contractchoice.php?sales_id=".rawurlencode($row_W ADAsales['sales_id']);
The following doesn't pass the URL.salesID
<cfset WA_redirectURL = "bundle_Results.cfm?salesID=" & ToString(getSalesID.salesID) & "" />
dp
The code you have looks like it should set the variable ok to me.
What is the result you are getting with this value? If there is nothing specified for the sales id then it is probably because the getSalesID.salesID does not have a value. Just before this line of code you should add in a cfoutput and print this value, you can follow that by a cfabort to stop the processing. When you test this out it should print the value to the screen. You will need to ensure this recordset variable has a value for it to link correctly.
