DynamicWebCharts/Data/MainPage_dataparser1.asp?
Thread begun 1/25/2012 2:09 pm by rbutcher435031 | Last modified 2/27/2012 3:34 pm by Jason Byrnes | 5082 views | 12 replies |
rbutcher435031
Not sure why I get DynamicWebCharts/Data/MainPage_dataparser1.asp? when I attempt to get a dyname chart static charts seems to work? using dw3 with SQL back end.
please post a link to your chart.
also a copy of the DynamicWebCharts/Data/MainPage_dataparser1.asp and the DynamicWebCharts/Data/MainPage_data1.asp pages would be helpful in a zip archive
rbutcher435031
Site is behind a firewall Intranet site
Attached are the files
rbutcher435031
forgot main page
MainPage attached
victor367017
/DynamicWebCharts/Data/Stats_M_chart_dataparser1.asp?
I am having the exact same problem.
The data can be displayed but I get the message /DynamicWebCharts/Data/Stats_M_chart_dataparser1.asp? after flash starts.
I am using CS 5.5. I am providing you the same files that you asked for in response to an earlier problem. In addition I have provide a copy of the ASP page that I am trying to put the dynamic chart as well as a text file with the url that is failing.
visiting the page that creates the chart data:
/DynamicWebCharts/Data/Stats_M_chart_data1.asp
shows the following error message:
Active Server Pages error 'ASP 0131'
Disallowed Parent Path
/DynamicWebCharts/Data/Stats_M_chart_data1.asp, line 2
The Include file '../../Connections/pcuser.asp' cannot contain '..' to indicate the parent directory.
to correct the problem, edit your dreamweaver site definition, on the Local Info tab set the "Create Links relative to" option to Site. this will cause dreamweaver to use "include virtual" instead of "include file" when adding the connection to the chart page.
you will need to recreate the chart after making this change.
victor367017
I already had that in place so that is NOT the solution.
on the /DynamicWebCharts/Data/Stats_M_chart_data1.asp file, try changing:
<!--#include virtual="../../Connections/pcuser.asp" -->
to:
<!--#include virtual="/Connections/pcuser.asp" -->
victor367017
Did that and I get the message
