Site Import Crashes Dreamweaver
Thread begun 1/19/2012 12:31 pm by stevehorn357697 | Last modified 9/03/2012 10:38 pm by shootersolutions | 3214 views | 4 replies |
stevehorn357697
On Snow Leopard, Site Import crashes Dreamweaver consistently. Tried on two computers, last one using 2.66 Quad Core i5 w/8GB DDR3. I should have plenty of power but Dreamweaver crashes every time. This didn't used to happen. Is there an update available to keep up with Apple's updates?
what version of site import?
what version of Dreamweaver?
Delete the Dreamweaver Cache file from the users configuration folder:
stevehorn357697
versions
Dreamweaver CS4 and SiteImport 3.0.2
Still Crashes.
shootersolutions
I'm seeing the same thing in Windows 7 Dreamweaver cs6 after deleting the older extensions to add the new ones, and installing the latest two extensions of Aug 28th. I never had this issue occur in the previous rev. Is there a cache I need to delete or something?
I got this working on Dreamweaver CS6 by closing out CS6, and then opening Site Import Dialog back up again, same place, and this time I was asked to activate the extension, which I did, and worked fine then in CS4. Once done with that, Opened back CS6 again, and it is activated and no more crashes.
So in CS6, rather than asking for Activation code, it crashed out the application. (Previous version did not do that - I just happed to own CS4 and have CS6 (Well CS6 is an Adobe year comittment)
I hope that helps you Jason: When you get in that is.
More information: Closed Dreamweaver CS4 was looking for the install of Extension Manager CS6 instead of CS4, and I then closed down CS4 and upon reopening CS6, it continued working, so I believe it was a "not activated" error internal to the extension that was crashing CS6 rather than asking for activation code as in CS6. The new Databridge - which by the way I left ecart 5.06 alone: (I as using Site import as part of the full package not just it itself) - did ask for activation fine, so the combination of applications are up and running now.
jim.lawson444275
CS4 freezes and a crash during "import Pages"
When I try to import a web site DW cs4 runs very slow, had to do a hard shut down, will not complete the import
Dreamweaver may run slow while the site is importing, that is normal. Depending on the size of the site it, it may take some time for the import to complete.
