Dynamic Web Charts: Display 12 months
Thread begun 12/12/2011 10:28 am by theorytl401135 | Last modified 7/02/2012 6:28 pm by Miguel | 2314 views | 1 replies |
theorytl401135
How can I add make a chart display dynamic data by month but with 12 months showing?
If I group my data by month now I get only the data that exist in my table but I would like the data to be shown specifically by the current year and all 12 months displaying even if there is no data.
I am using a time-stamp to mark my records.
Miguel
Hello theorytl401135, in order to do this you would need to do some hand code, go to the folder where the data parsers are of the charts that if you have the new version would be
domain/webassist/open_flash_charts/
Open in dreamweaver your data file something like:
chartname_data#.php where # is the number of the file and chartname_ is the name of your chart.
look for the recordset and add a where clause
example:
add this to the where you will add
WHERE DateField >= '(DATE_SUB(NOW(), INTERVAL 1 YEAR))' AND DateField <= 'NOW()'
this will get the todays date and only show the last 12 month
another more complete example, this is how it comes out directly from the wizard
$query_WADWCTable = "SELECT CONCAT( LEFT(MONTHNAME(dateField), 3), ' ', YEAR(dateField)) AS XLABEL, COUNT(idUsers) AS YVALUE
FROM TABLENAME
GROUP BY CONCAT( LEFT(MONTHNAME(dateField), 3), ' ', YEAR(dateField)), YEAR(dateField), MONTH(dateField)
ORDER BY YEAR(dateField), MONTH(dateField) ASC";
so after the wizard finish i just add the where clause to the query
FROM TABLENAME
WHERE  dateField>= '(DATE_SUB(NOW(), INTERVAL 1 YEAR))' AND dateField<= 'NOW()'
so again to make it more understandable we are using a function that exist in php library's called INTERVAL
INTERVAL 1 YEAR
INTERVAL 15 DAYS
INTERVAL 4 MONTH
You can combine it any way you want, and finally we are using the NOW()
NOW() = Gets the actual date on the server
The trick of this is creating a between dates set up manually this gets it dynamically
Hope this helps lets us know
Sades
