no results on details page after insert
Thread begun 7/16/2009 2:11 pm by tige247759 | Last modified 7/16/2009 2:49 pm by tige247759 | 2350 views | 2 replies |
tige247759
I created a set of cf files using the wizard. When I insert a new record, it normally goes to the details page and shows the record with the ASP sets I have created, but this time the details page wont show the entered record. However the insert works because I can see the record on the results page.
A possible clue: after running the wizard to create the cf files, I got this error while the wizard was compiling the pages:
TypeError: this.transMgr.CFOutput.Push is not a function
Any ideas?
You don't have an applicaiton.cfm defined to start your session and session variables aren't being stored properly.
tige247759
Ahh that did the trick. It must be painful sometimes watching us noobs flounder about. In case anyone is wondering, I used an example application.cfc file that I found here:
index.cfm?mode=entry&entry=585F0E1E-E19B-31A5-4357446E2AF47653
Thanks for your help with this.
