UPDATING issue within the admin_cms section of Power CMS
Thread began 11/29/2011 4:52 am by Rune Brynestad | Last modified 12/08/2011 10:37 am by Rune Brynestad | 3964 views | 9 replies |
Rune Brynestad
After making a simple change on a selected page, I clicked the UPDATE button to update the site with the new content. Instead, I received the following message in a call-out box right above the Content Location field.
Message = "This field accepts alphanumeric characters only." See attached picture. The page will not complete the update to the site.
As you can see from the picture I get the message because I'm using the norwegian letter å in the content location field. Sometimes the user need to use letters like this, so I need to change the validation rule. How and where do I change it?
Regards
Rune
in the js/editable_select.js file, change line 79:
dest.className="selectBoxInput validate['required','alphanum']";
to:
dest.className="selectBoxInput validate['required']";
Rune Brynestad
What about Power Store 4.5 ?
Thanks. It works perfect in Power CMS Builder.
However, I have the same problem in the CMS Section of Power Store 4.5.
I tryed the same approach there, but it did not work.
How do I solve this problem in Powerstore 4.5 ?
Thanks again.
Regards
Rune
It's the same fix in power store.
make sure to clear your browsers cache, it may not be working because the script has been cached by the browser.
Rune Brynestad
Yes, it was the browser cache.
Works perfect now.
Regards
Rune
Rune Brynestad
Same problem for the Add New Content Location
Sorry to bother you again with this, but I have exactly the same problem with the Add New Content Location. See attached picture.
Regards
Rune
in the admin_cms/contents_insert.php page, change:
<input type="text" name="ContentGroup" id="ContentGroup" class="validate['required','alphanum']" /><br />
to:
<input type="text" name="ContentGroup" id="ContentGroup" class="validate['required']" /><br />
Rune Brynestad
Sorry, I could not find this line in the admin_cms/contents_insert.php page.
The one that is closest is
<input type="text" name="ContentRefID" id="ContentRefID" value="<?php echo((isset($_POST['ContentRefID']))?$_POST['ContentRefID']:"") ?>" class="validate['required','alphanum']" />
which i changed to
<input type="text" name="ContentRefID" id="ContentRefID" value="<?php echo((isset($_POST['ContentRefID']))?$_POST['ContentRefID']:"") ?>" class="validate['required']" />
The change made no difference.
I'm attaching a copy of my admin_cms/contents_insert.php file
Regards
Rune
contents_insert.zip
OK, on the admin_cms/pages.php file, change:
to:
Rune Brynestad
Perfect.
Thanks again.
Regards
Rune
