Simple if...else help needed
Thread begun 10/11/2011 9:50 am by Jared Lui | Last modified 10/11/2011 1:34 pm by Jared Lui | 1388 views | 2 replies |
Jared Lui
For some reason I cannot use the same technique that I used to only show if a value is found in a database query.
My goal: the first <tr> should display if a user is logged in. If not the second <tr> should display.
Using the code below, the first <tr> does display correctly if the user is logged in and the second <tr> does not display. This is the desired outcome. However, if no user is logged in, neither <tr> displays. The desired outcome is for the second <tr> to display only.
I have tried several different operator combinations as well as using a different SESSION for one or the other statements thinking the code was confused.
I believe I need to use an if/else statement instead. I've looked through several tutorials and it seems like it would be straight forward but I either show no results or errors. I could use some guidance.
Thanks in advance!
<?php if($_SESSION['Username'] != "") { ?>
<tr>
<th class="formTable">Username:</th>
<td class="formTable"><?php echo $_SESSION['Username']; ?>
<input type="hidden" name="Reg_Username" id="Reg_Username" value="<?php echo $_SESSION['Username']; ?>" size="32" /></td>
</tr>
<?php } ?>
<?php if($_SESSION['Username'] = "") { ?>
<tr>
<th class="formTable">Name:</th>
<td class="formTable"><input type="text" name="Name" id="Name" value="" size="32" /></td>
</tr>
<?php } ?>
make sure you start the session before trying to compare the session value.
use:
<?php @session_start(); ?>
before the first if statement.
instead of:
<?php } ?>
try using:
<?php } else { ?>
Jared Lui
I was so close!
I had started the session so that wasn't the issue but a good reminder none the less.
My if/else statement attempts had it all correct except I was missing the "?".
I had: <?php } else { >
Instead of: <?php } else { ?>
Thanks once again Jason. Learning more and more everyday!
