Search Wizard
Thread begun 7/12/2009 7:29 pm by mcriecken380554 | Last modified 7/13/2009 10:19 am by Ray Borduin | 1724 views | 1 replies |
mcriecken380554
Search Wizard
I have created a results page and a search page, and they both work fine. However, when I use the Data Assist Search wizard to add search options to a separate page, I'm running into problems. Everything works well in dreamweaver, but after I upload to my server the results page no longer loads at all for either search page. My browser says it is 'Done', but it has loaded a completely blank page.
Is there a problem when linking to separate search pages to a single results page? I'm thinking there's something I'm missing, but I've messed around with it quite a bit and can't seem to come up with anything. Any help would be appreciate. Thanks.
-Matt
You should not run the wizard again when creating a new search page for a single results page.
Instead you should create the search form with Dreamweaver manually and update the server behavior without entering the wizard.
