Ordered and unordered lists
Thread begun 8/03/2011 5:12 am by jack343289 | Last modified 8/04/2011 7:09 am by Jason Byrnes | 4269 views | 7 replies |
jack343289
I am having difficulty validating bullited lists, so I downloaded an example from www.w3.org
Here it is:
<UL>
<LI> ... Level one, number one...
<OL>
<LI> ... Level two, number one...
<LI> ... Level two, number two...
<OL start="10">
<LI> ... Level three, number one...
</OL>
<LI> ... Level two, number three...
</OL>
<LI> ... Level one, number two...
</UL>
When checked by the advisor it gets the "thumbs down" for several of the elements.
Which brings me to two questions:
1. Has this software programme become corruped somehow?
2. Is there an error in this programme?
Regards
Jack
please post the errors that the advisor is giving you and a copy of the page in a zip archive so can examine what the problem is to determine the cause.
jack343289
Files uploaded
Enclosed are the files you requested
Regards
Jack
the doctype being used on your page:
is the XHTML 1.0 Transitional doctype.
in the XHTML 1.0 Transitional doctype, all html tags must be in lower case.
instead of:
<UL>
<LI> ... Level one, number one...</LI>
</UL>
it should be:
<ul>
<li> ... Level one, number one...</li>
</ul>
jack343289
In reply
Jason, thank you for your help in this matter.
I have changed all the tags to lower case but I still get the error results (see attached)
Any ideas?
Thank you
Jack
you are not writing semantically correct html.
you need to close the <li> tags before starting another, instead of:
you should have:
jack343289
Sorry
Oops I zipped up the wrong file - here is the correct one
the xhtml doctype does not allow for an ordered list (<ol>) to be nested in an unordered list (<ul>)
