File Manager using wrong file path
Thread begun 7/28/2011 1:47 pm by emily425525 | Last modified 7/29/2011 2:12 pm by emily425525 | 6454 views | 6 replies |
emily425525
I'm working with the File Manager portion of the HTML Editor (in this page, this is independent of the HTML editor).
No matter what I try the file path that is inserted into the database is
/siterootdirectory/imagedirectory/file.ext
That /siterootdirectory/ will make the files invalid once I make this site live. On my testing machine the siterootdirectory will be something like "sitename" but on the live server the root directory will be "public_html"
Even if I set the paths to recall the data to ../siterootdirectory/ it won't work because the siterootdirectory isn't the same name from local to live server.
Please advise how to change this.
I have tried putting the imagedirectory inside the same directory as the page with the file manager upload, I have tried changing all sorts of settings.
From reading the forum it wold appear there is a place to change the "root directory" but I can't find a folder for "HTML Editor" anywhere in my site files.
Using PHP, HTML Editor 3.01. Dreamweaver CS3, Mac OSX. Server is MAMP.
Thank you.
since the content added to an html editor instance needs to display correctly on any page of your site, the image path needs to be relative to the server root.
for this to work from a testing server to a live server, you need to set the testing server up using the same site relative path.
one way to accomplish this is to use a subdomain for the testing server:
test.mydomain.com/
this way the same site relative path that works on the subdomain will work on the live domain.
emily425525
I don't think you understand what I'm asking. I know that the server paths and setup must be the same.
On my computer I have many sites set up.
their server addresses are
thesitename/
On the testing webserver the addresses will be
thesitename/
On the live webserver the address will be
www.thesitename.com
Right now the File Manager uploads into the correct place, but the file path it saves in the database is:
/thesitename/media/file.ext
/thesitename/ is not necessary that is the folder/root of the website and does not exist on the webserver.
I think that File Manager things that the root of the site is actually the htdocs folder rather than thesitename folder.
I have looked through the forums and found references to an HTML Editor folder that should be present in the website's directory along with all the other webassist folders - that folder is not there. Please advise - how do I find out what HTML Editor considers to be the site root.
I understand what you are asking.
the problem is that your testing environment contains a sub directory:
thesitename/
whereas the live server does not:
www.thesitename.com
any subdircetory on the end of the domain name will be added to the image paths:
so if your site is at:
thesitename/
the image paths will be:
/thesitename/images/imageName.jpg
the way around this is to use a sub domain, rather that a sub directory, for example
www.thesitename.mytestingserver/
most hosts will offer around 50 sub domains for any one main domain.
by using the sub domain, the paths for the testing server become consistent with the paths on the live server.
emily425525
I don't know of anyway to force MAMP to use a subdirectory for local testing on my machine.
Why is the HTML editor deciding that the site root is up one directory from where it actually is. Why is it using /htdocs/ as the site root. I have dozens of sites /htdos/site1/ /htdocs/site2/ and so on...Shouldn't each site have it's own site root directory?
On the webserver it is set up the same way.
/public_html/ is eqivalent to my /htdocs/ folder
The full file paths are:
Local Machine: /htdocs/mysite/
Testing: /public_html/mysite/
Live site: /public_html/mysite.com
This doesn't make sense to me.
because that is the actual site root as far as the domain is concerned.
"Site" means different things in different contexts.
in mamp, the address:
localhost/
maps to the the htdocs directory
if you create a subdirectory:
htdocs/mysite/
the root of the site:
mysite/
is still at:
htdocs/
it is just looking up one directory from the root to:
htdocs/mysite/
by creating the subdirectory you are not creating a new website.
you can set mamp up to use subdomains which would map the new sudirectory to a new site address.
you could set it up to map the address:
mysite.localhost/
to the folder:
htdocs/mysite/
using the subdomain approach:
mysite.localhost/
the subdirectory now becomes a new site.
I think you are confusing the Dreamweaver "Site" concept and applying that to your sites host, the concept of the site host is different than that in Dreamweaver.
i found a tutorial for setting up sub domains in mamp here:
subdomains-for-mamp-dev-environment/
emily425525
Thank you, setting up the subdomains fixed the issue.
Much appreciated!
