Debugging Payflow Failed transaction
Thread begun 7/18/2011 2:02 pm by CraigR | Last modified 7/19/2011 10:07 am by Jason Byrnes | 3627 views | 2 replies |
CraigRBeta Tester
Can someone give mehelp to debug a failed Payflow Pro transaction ?
I added the local checkout response bi9nding to the page and I dragged the full response binding
<?php echo(_Result("Full Response")) ?>
on the page, but nothing appears
when i displayed php errors, i got
Fatal error: Call to undefined function _Result() in D:\vhosts\csc_payflowpro\Store\checkout_failure.php on line 144
also, (just for my peace of mind) if the lines
$PP_PayPro_required[0][$nextIndex] = "TESTING";
$PP_PayPro_required[1][$nextIndex] = "true";
the transaction always seems to be a success
$PP_PayPro_required[1][$nextIndex] = "false";
the transaction always seems to fail. Is this what I should expect ? ie if the account criteria are correct, the transaction would always succeed in a test environment, regardless of the c/c info.
CraigRBeta Tester
Error code
i managed to get the error codes eventually using this...
if(!session_id()) session_start();
     echo
"<p>Payflow Pro: <br />"
     echo
"Full Response: ".(isset($_SESSION["PP_PayPro"])?htmlentities($_SESSION["PP_PayPro"]):"n/a")."<br /></p>";
     echo
     echo
"Full Request: ".(isset($_SESSION['PP_PayPro_postedValues'])?htmlentities($_SESSION['PP_PayPro_postedValues']):"n/a")."<br />"
So thats part of the problem solved.
Still interested in a view re successful transactions in the testing environment
yes, in the testing environment, the credit card details are ignored, it is considered a successful transaction if it passes through the paypal system. the paypal system never contacts the merchant bank to check the credit card when the sandbox is enabled .
