To reject on Like Entry
Thread begun 7/09/2009 9:07 am by quy355499 | Last modified 12/14/2009 3:10 pm by Jason Byrnes | 3857 views | 5 replies |
quy355499
Instead of passing on Like Entry, how to reject on Like Entry. For example, there have been many bogus submissions where the values of First Name and Last Name fields are the same. How to accomplish this? Thanks.
Are you using client or server validation?
quy355499
Server validation.
I suppose you could do it with a little php...
Use required validation on :
<?php echo((isset($_POST['firstField']) && isset($_POST['lastField']) && strtoupper($_POST['lastField']) == strtoupper($_POST['firstField']))?"fail":""); ?>
that should fail required validaiton if the two fields were the same... just a warning though... I knew a kid named "Jackson Jackson" in high school.
webmaster286369
Client side reject on 'Like Entry' (with an ID number)
How can I do this same thing with client side validation? Basically it would allow an update or insert only if 2 fields DO NOT MATCH. Is there any way to make 'Like Entry' behaves as 'Not Like Entry'
Specifically, i want to prevent a user from creating cheque requisitions for himself as the recipient. Their own user id is automatically captured, and they input the recipient. I compare both fields, and don't want to allow if they match.
Help?
When you apply like entry validatin, it creates the following function in the script tag:
function WAValidateLE(formElement,value1,value2,errorMsg,focusIt,stopIt,required)  {
var isValid = true;
if (!document.WAFV_Stop && !formElement.WAFV_Stop) {
if (value1=="" && required)
isValid = false;
if (value1 != value2 || (required && value1==""))
isValid = false;
if (!isValid) {
if (focusIt)
focusIt.value = "";
WAAddError(formElement,errorMsg,focusIt,stopIt);
if you change that to:
var isValid = true;
isValid = false;
if (value1 == value2 || (required && value1==""))
isValid = false;
if (!isValid) {
if (focusIt)
focusIt.value = "";
it will reverse it to fail if the two values are the same.
