Help with SQL Statement
Thread begun 7/08/2009 11:38 am by tige247759 | Last modified 7/08/2009 12:32 pm by tige247759 | 2748 views | 4 replies |
tige247759
I have a results page made with DataAssist. I need to join data from 4 tables in an access database so that the common names get displayed instead of the number relations. Here is my modified SQL Statement:
"SELECT tasktypes.*, tasks.*, projects.*, clients.* FROM ((projects INNER JOIN clients on projects.clientid = clients.clientid) INNER JOIN tasks on projects.projectid = tasks.projectid) INNER JOIN tasks on tasktypes.tasktypeid = tasks.tasktypeid"
It worked fine until I added the 3rd join. Now I get this error:
Microsoft OLE DB Provider for ODBC Drivers (0x80040E14)
[Microsoft][ODBC Microsoft Access Driver] Syntax error in JOIN operation.
Can anyone help with this?
PS:
The one that worked fine looked like this:
"SELECT tasks.*, projects.*, clients.* FROM (projects INNER JOIN clients on projects.clientid = clients.clientid) INNER JOIN tasks on projects.projectid = tasks.projectid"
It returned the common name for the client and the project. Now I just want the common name for the task to be in there as well.
You join the same table twice!?
Notice INNER JOIN tasks appears twice
tige247759
Yup, I know (this is the first time I have ever tried hand coding SQL so I know it sucks)
In the tasks table, I reference a projectid (projects table), a clientid (clients table) and a tasktypeid (tasktypes table). How do I make sure all the id numbers are joined with their counterparts in the other three tables?
Instead of:
use:
INNER JOIN tasktypes on tasktypes.tasktypeid = tasks.tasktypeid
tige247759
Yes, that worked. I see it clearly now. Now all of the DataAssist server behaviors have a red exclamation mark beside them, but the page is loading correctly and displaying the correct data. Thanks so much for your help.
