indexed array from recordset
Thread begun 6/27/2011 5:01 am by CraigR | Last modified 6/28/2011 10:41 am by Jason Byrnes | 3106 views | 6 replies |
CraigRBeta Tester
I am trying to create a simple, indexed array from a recordset, but cannot seem to get it in the correct format.
I am retrieving a single field, EMail.
If I was to do this manually, it would look like
$emailarray = array('name1@address.com', 'name2@address.com','name3@address.com');
and if i did a print_r($emailarray);
it would look like
Array (     [0] => name1@address.com     [1] => name2@address.com     [2] => name3@address.com )
which is exactly what i want
when i try and do the same using a recordset, i cannot get the same result.
If I try
$emailarray = array();
do {
$emailarray[] = $row_rsmembersreplied;
} while ($row_rsmembersreplied = mysql_fetch_row($rsmembersreplied));
i get
Array (     [0] => Array         (             [email] => name1@address.com         )      [1] => Array         (             [0] => name2@address.com        )      [2] => Array         (             [0] => name3@address.com         )  )
If I omit the [] within the do..while loop. i get the correct format, but only one row returned
try changing:
to:
$emailarray[] = $row_rsmembersreplied['email'];
just using $row_rsmembersreplied is returning an array of the column name => column value
CraigRBeta Tester
Hi Jason,
just got around to trying this, if I make the change as suggested i get
Undefined index error
i have attached a version of the page - thanks
then try using:
$emailarray[] = $row_rsmembersreplied['MemberEmail'];
and dont cast the MemberEmail to an alias in the SQL:
SELECT MemberEmail AS email
CraigRBeta Tester
doesn't make any difference, i tried it with and without the alias
CraigRBeta Tester
hi Jason.
fixed it.
my line should have read mysql_fetch_assoc($rsmembersreplied));
whereas it read
thanks for your help
glad to hear it is working.
