Search recordset based on cookie value
Thread begun 6/22/2011 4:54 am by acaciasd344844 | Last modified 6/30/2011 7:33 am by Jason Byrnes | 5424 views | 8 replies |
acaciasd344844
Hi Jason,
You helped me out last time, so here goes. I did look for my older posts but couldnt find them. One of my clients wants their field operatives to be able to view tomorrows work on the login screen before the user has logged in. So using a cookie I can store the users name after the initial login. What I need to know is how do I call the cookie username and compare it to the name held in the database.
for example WHERE appointments.date >= DATE_SUB(CURDATE(),INTERVAL 1 DAY) and employees.emp_name = colname1
Sorry if you have told me before but thanks again
john
is it a cookie or a session?
your where clause:
suggests you have a variable in the recordset named colname1.
in the advanced view for the recordset, go to the variables section, and edit the colname1 variable to:
type: text
Default value: -1
Run Time Value: $_COOKIE['username']
if it is a session, not a cookie, then:
Run Time Value: $_SESSION['username']
acaciasd344844
Hi Jason,
Thanks for your reply. I dont seem to have much luck with cookies for some reason, I dont know what it is!!! lol.
Here is what is going on, when a user logs into the web page first time, their Username is stored in a cookie (to last 365 days, that's what I set it at) on a mobile device. The user then completes their work orders and finally logs out.
This means the next time they go to the login page it will automatically check who the user is using the cookie; display the following days work order count associated with that particular engineer. So I guess if the work order count is zero then they wont login. Saves a bit of time for them. So no Session variable in use.
So so far I have selected the Form on the page and got it to 'Set Cookie Value' to 'cookusername' and this is retrieved from the username field. I then went to the body section of the page and 'Set The Form Element From' 'cookusername'. So now when the page loads I can see the users name already sitting in the username field.
So far its working fine:
When I try to use it as a variable in the recordset it doesn't work. The recordset works without the variable and displays all the records for every user. Below is the SQL code and basically it shows all work orders for the following day only.
SELECT *
FROM workorders LEFT JOIN customers ON workorders.customerid = customers.customerid
WHERE workorders.workorderdate BETWEEN DATE_SUB(CURDATE(), INTERVAL -1 DAY) AND DATE_ADD(CURDATE(), INTERVAL 1 DAY) and workorders.employeename = colname
The colname variable details are
Type: Text
Default value: -1
Runtime value: $_COOKIE['cookusername']
I have checked that the usernames in the database table are all spelt correctly but still nothing!!!
Can you help?
Thanks Jason
send a copy of your page please.
acaciasd344844
This post has been deleted.
acaciasd344844
acaciasd344844
Here you go ...
at last sorted
this page does not have a recordset using the cookie?
I need to see a copy of the page with the recordset on it that uses the cookie value.
acaciasd344844
Sorry bout that, I had to remove the variable so I could continue working on the additional files.
This next attachment does have it in...
acaciasd344844
Hi Jason
Did you have any luck with the file I sent you?
john
