Cannot Connect MySQL Database
Thread begun 7/07/2009 9:16 am by susan346031 | Last modified 7/07/2009 12:51 pm by susan346031 | 13159 views | 24 replies |
susan346031
I am unable to connect to the database and test Powerstore. I have been able to make a successful localhost connection in Dreamweaver and using the store.sql information (imported to my database & table) but no luck.
Notice: Undefined variable: database_test in C:\htdocs\DurableToys\CSSMenuWriter\cssmw_home\menu.php on line 65
Notice: Undefined variable: localhost in C:\htdocs\DurableToys\CSSMenuWriter\cssmw_home\menu.php on line 65
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in C:\htdocs\DurableToys\CSSMenuWriter\cssmw_home\menu.php on line 65
Notice: Undefined variable: localhost in C:\htdocs\DurableToys\CSSMenuWriter\cssmw_home\menu.php on line 67
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in C:\htdocs\DurableToys\CSSMenuWriter\cssmw_home\menu.php on line 67
In the menu.php, lines 65 & 67, here is the code:
65 mysql_select_db($database_locahost, $localhost);
67 $menuwriter_productcategories = mysql_query($query_menuwriter_productcategories, $localhost) or die(mysql_error());
Since it references $localhost, I also checked localhost.php--
$hostname_localhost = "localhost";
$database_localhost = "test";
$username_localhost = "durable";
$password_localhost = "****";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
Any help would be appreciated! :)
SH
According to the error you have $database_test on line 65 and not $database_localhost so maybe you didnt' upload the page but it seems like the code you are showing does not correspond to the code generating the error.
susan346031
Hi Ray,
You are correct, I tried to specify the specific table, but even with database_localhost, the error is the same. I refreshed, here is the current error.
Notice: Undefined variable: database_locahost in C:\htdocs\DurableToys\CSSMenuWriter\cssmw_home\menu.php on line 65
Thank you
That means that the page you are viewing doesn't have a require_once() for the connection. That is why the variable is not defined. Add the connection include on top of the page where the menu is located and it should correct the problem.
susan346031
There is an includes command in the menu.php page. Do I need to modify it?
<?php require_once('../../Connections/localhost.php'); ?><?php } // End MenuWriter ignore connection includes ?>
susan346031
When I went to the Live Data view in Dreamweaver on menu.php, I also got an error regarding the WA_Globals
(An error occurred while requesting the document from the testing server:)
Notice: Undefined variable: WAGLOBAL_localRoot in C:\htdocs\DurableToys\CSSMenuwriter\cssmw_home\menu_3fgoomf88b.php on line 2
Notice: Undefined variable: WAGLOBAL_remotelRoot in C:\htdocs\DurableToys\CSSMenuwriter\cssmw_home\menu_3fgoomf88b.php on line 3
Warning: strpos() [function.strpos]: Empty delimiter in C:\htdocs\DurableToys\CSSMenuwriter\cssmw_home\menu_3fgoomf88b.php on line 6
Warning: strpos() [function.strpos]: Empty delimiter in C:\htdocs\DurableToys\CSSMenuwriter\cssmw_home\menu_3fgoomf88b.php on line 10
Here are the lines (2 & 3 of the menu.php in reference to WA_Globals
$WA_localRoot = "".$WAGLOBAL_localRoot."";
$WA_remoteRoot = "".$WAGLOBAL_remoteRoot."";
and 6 & 10
if ((strpos($WA_curURL,strtolower($WA_localRoot)) !== false && strpos($WA_curURL,strtolower($WA_localRoot)) == 0) && (strlen($WA_localRoot) >= strlen($WA_remoteRoot) || strpos($WA_curURL,strtolower($WA_localRoot)) === 0)) {
$assumedRoot = $WA_localRoot;
if (strpos(strtolower($WA_thisFile), strtolower($assumedRoot)) === 0) {
$WA_thisFile = substr($WA_thisFile, strlen($assumedRoot));
Here is the info in WA_Globals:
$WAGLOBAL_localRoot = "/DurableToys/";
$WAGLOBAL_remoteRoot = "/DurableToys/";
Local Root is C:\htdocs\DurableToys\
Remote Root is DurableToys/
susan346031
Here are the includes (including WA_Globals) for the index.php page
I believe this is what you're referring to....
<?php require_once( "WA_Globals/WA_Globals.php" ); ?>
<?php require_once('Connections/localhost.php'); ?>
Is that the page you are browsing when you see these errors? Are those on top of the page? That doesn't make sense... are you sure you are viewing that page. If so it should not say those variables are not defined because they are defined in that include.
susan346031
Yes, I am refreshing the index.php page, with those includes that return those errors.
Do you have a url where I can view it? Maybe the locations of those files has changed? If they are included, and the variables are defined in them, then you should not get an error that those variables are not defined.
