popup alert if no check boxes are selected
Thread begun 6/17/2011 8:52 am by CraigR | Last modified 6/29/2011 8:33 am by Jason Byrnes | 39364 views | 11 replies |
CraigRBeta Tester
have a multiple add to cart form, which inserts into the cart array if the checkbox is checked
want to popup a message to warn if nothing is checked, before form is posted.
got this, but alert pops up everytime, even if checkbox is checked.
function addToBasket(form) {
var isChecked = false;
if ( document.forms['add_to_cart'].elements['atccheck[]'].checked == true) {
isChecked = true;
else {
for ( var i=0; i < document.forms['add_to_cart'].elements['atccheck[]']; i++) {
if ( document.forms['add_to_cart'].elements['atccheck[]'][i].checked == true ) {
isChecked = true;
break;
if ( isChecked == false ) {
alert("Please select a spring. Then press 'Add to Basket'.");
else {
form.submit();
</script>
please send a link to your page so i can test this in the browser.
CraigRBeta Tester
here's a link to a representative page
test.php
click on 'find part' to show result table
client validation is problematic with checkbox group arrays, you should use server side validation on the checkbox group instead.
CraigRBeta Tester
Ok, can i do this via the server validations interface ?
I'm not sure what criteria to select.
I tried Required/Not Blank/Selection made on atccheck[] being posted, but if i have 50 rows, i only need one to be checked for the entry to be valid.
Yes, use the required not blank validation.
select any one of the atcheck form elements, the only thing you will need to change is that the code will be added using the "[]" in the name:
$_POST["atccheck[]"])
remove the square brackets:
$_POST["atccheck"])
CraigRBeta Tester
thanks Jason.
Sorted
you're welcome.
CraigRBeta Tester
client really wants 'client side' validation
it would be nice to achieve this without resorting to server side validation and reloading the page.
i have looked at the documentation re implementing spry validation on checkboxes and groups of checkboxes.
i can get it to work with a simple example, but if i use a checkbox array, the validation only works on the first checkbox.
ok, try using this for the script:
var chks = document.getElementsByName('atccheck[]');
if ( chks.checked == true) {
isChecked = true;
else {
for ( var i=0; i < chks.length; i++) {
if ( chks[i].checked == true ) {
isChecked = true;
break;
return isChecked;
</script>
and this for the submit button:
<input name="submit" type="submit" value="Add to Cart" onclick="return addToBasket()" />
