OnBlur validation not functioning
Thread began 5/26/2011 4:41 pm by MBrem | Last modified 5/27/2011 9:28 am by Jason Byrnes | 814 views | 5 replies |
MBrem
I'm using Form Builder 2.0 with DW CS5 on Mac 10.6.7
I've installed and customized a form based upon the stock Simple Registration including validation. However, the OnBlur validation does not function. I've deleted and recreated the form plus verified that all required folders have been uploaded. Below is the header php code. (BTW, I just noticed that there is a misspelling in the _POST function - I did try correcting that but did not have success with the validation)
<?php require_once("../webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("../webassist/form_validations/wavt_validatedform_php.php"); ?>
<?php require_once("../webassist/email/mail_php.php"); ?>
<?php require_once("../webassist/email/mailformatting_php.php"); ?>
if (!isset($_SESSION))session_start();
if ((isset($_POST["SimpleResgistration_submit"])))
No errors display. The form emails the info a-ok.
Mark
please send a copy of the page in a zip archive so I can examine the code.
MBrem
Hi Jason,
The .zip is attached.
Mark
you're form elements do not follow proper naming rules.
The following rules must be followed when naming form elements:
1) Only letters and numbers are allowed, the only exception if the underscore "_"
2) The first character of the name must be a number.
your form element names contain the dash "-"
this is interpreted in javascript as the minus operator.
your form element name:
Event-Name
is interpreted by the script as
Event minus Name
which throws a javascript error since you cannot perform math operations on a string.
MBrem
That was it. Thanks so much for your insight. I looked at those 100 times and didn't see the hyphen.
No worries
