Writing HR color CSS?
Thread begun 7/01/2009 10:03 am by RobertB | Last modified 8/26/2009 9:27 am by Justin Nemeth | 8786 views | 7 replies |
RobertB
In sculptor, you can easily color code a border color, but where do you config for a horizontal rule? HR
Justin Nemeth
To style an HR, you would have to add some custom CSS after running the Sculptor wizard. You can use the built in CSS functionality in Dreamweaver to accomplish this.
RobertB
can you give me a hint where that would be or how I would write it....I see nothing in DW for horizontal rule or HR. Thanks Justin.
RobertB
Ok....I found some stuff on the web...it seems that with 2px or less, the default is always black...I even tried a background image.....Have you seen any successful workaround for 2px?
You can always stretch an image in place of an hr for more style control.
Justin Nemeth
Nowadays I tend to use borders to accomplish the same effect as a hr tag. So rather than a div, hr, div - i would eliminate the hr and just give a bottom-border and margin-bottom to the first div. This simulates the hr tag. Maybe something like that would work for you? Plus that technique is natively supported in Sculptor.
bfallis215304
adding borders
this is a question I've had using Sculptor. Say I create a 2 column format. I always think there should be a way to add a border to the content area below the header and above the footer, but since these two columns are not equal in height, I can't just add borders to either column either, and there's no easy way to create faux columns either (speaking of CSS Sculptor 1.0). I assume there must be an easy way to add a bg image to create a faux column but it isn't made clear in the structures I've built on Sculptor. Has that changed in 2.0 by the way? And what is the best method to add a border to the area specifically above the footer and below the header?
Thank you.
Justin Nemeth
Sounds like you can put a bottom border on the header and top border on the footer to accomplish what you need.
