All the latest Suite Extensions - Javascript error CS5
Thread begun 4/21/2011 7:08 am by Art | Last modified 4/21/2011 7:36 am by Art | 2988 views | 3 replies |
Art
  JavaScript error(s) occurred:
Unable to open script file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver\CS5\Configuration\Shared\WebAssist\FormValidations\WAFV_SSVariable_SB.js" (error 3).
I get the above error - CS5 with all the latest extensions installed.
I tried to find this file but could not locate it or the Form Validations directory.
I'm in the process of uninstalling plugins but this is painfully slow...It could take the entire morning.
Any ideas as to which extension could be the problem here so that I can, perhaps uninstall/reinstall that problem extension?
And when I do start to install again, I plan to check each one before installing the next.
I just don't want to be wasting a lot of time on this.
Art
I can find that .js file for CS4 but not 5. It appears that something is looking for it and not finding it.
In order to open and then close DW5 I have to "OK" a whole bunch of error messages before I can move on.
Delete the Dreamweaver Cache file from the users configuration folder:
the quickest way to uninstall your extensions is to rename the Users Configuration folder and have Dreamweaver recreate it.
When you reinstall the extensions, Use the CSS Form builder 2.01 HTML Editor Compatibility version available in the download center.
If you are installing both Form Builder and Form Toolkit, install Form toolkit before installing Form Builder.
If you are installing HTML Editor 3, Install the CSS Form builder 2.01 HTML Editor Compatibility version Before you install HTML Editor.
After installing extensions, it's a good idea to Delete the Dreamweaver Cache file from the users configuration folder before loading Dreamweaver.
Art
Form Toolkit 1.0.0
Probably this one....
