Dynamic chart using two recordsets
Thread begun 4/15/2011 8:04 am by hbibizadeh396670 | Last modified 4/18/2011 7:15 am by Jason Byrnes | 2617 views | 3 replies |
hbibizadeh396670
Hi
I have made a directory.
I want to make a dynamic chart that shows the categories and the number of listings per category.
However, I have set up my directory so that I have two database files/tables. One for category and another for the listings.
I need to use two recordsets to make the chart, but in the dynamic charts interface I am not sure if it will allow me to do this.
Could you please conform if this is possible or not?
Thank you in advance
the wizard will only be able to use one table, but you can edit the recordset that is created after the wizard creates the pages and use a join query to get the data from the second table.
if you need help with this, post a copy of your page and the DynamicWebCharts/data folder.
I will need screen shots showing the schema for these two tables.
hbibizadeh396670
Thank you for your help.
I managed to sort it out.
Thanks again
glad to hear you have it working.
