Digi File Pro 1 and Dataassist2
Thread begun 6/30/2009 11:56 am by caswebsolutions | Last modified 6/30/2009 2:09 pm by caswebsolutions | 3858 views | 3 replies |
caswebsolutions
I've been messing about with trying to get the 2 of these to work together and i'm getting an error that i've come across before.
However, I'm not sure which option i'm supposed to select!!
I get the following error when i run the page and its because of the request.form action being used on a digi pro page.
Request object error 'ASP 0207 : 80004005'
Cannot use Request.Form
/ADMIN_StockInsert.asp, line 122
Cannot use Request.Form collection after calling BinaryRead.
i need to select the paramater from the lightening bolt for the form that has the file upload in it but under the form there are 2 insert options insert.x and insert.y
which one do i pick? don't want to select the wrong one and it knacker something up!!!
any help would be appreciated.
cheers
chris
They should both work. We usually use x, but when you click on an input type image the x and y coordinates of where you clicked are both posted.
caswebsolutions
cheers for the speedy reply ray, i may be back though lol i'm sure there'll be another 'hurdle' :D
caswebsolutions
right i made the changes and despite not finding 'request.form' in a search on the page i'm still getting the same error!!!
i've attached the full page code here, if someone can scan an eye over it for anything that looks wrong/out of place!!
also, in the live page the css seems to pot after adding data assist and the form is overrunning the footer!!! i've been going at things for so long today i just can't concentrate on the simple stuff now !!!!
any help, greatly appreciated.
Cheers
