checkbox in update
Thread begun 6/30/2009 6:09 am by Daryl | Last modified 10/12/2011 9:07 am by Jason Byrnes | 4971 views | 10 replies |
DarylBeta Tester
checkbox in update
How can I have the checkbox ticked in the update page if it is ticked in the database?
DarylBeta Tester
Please ignore - I figured it out with a bit of trial and error!
bill3786
Hi daryl
Please could you post the solution to this, I have the same problem.
DarylBeta Tester
I cant remember exactly....
I think I would have selected the checkbox on the update page, then clicked the lightening bolt.
Select the database column for the check if field (using the lightning bolt)
Make sure the value to Equal to is 1
Press OK
Make sure the checked value in the property inspector is also 1
bill3786
Thanks daryl
Tried your suggestion but doesnt give me what I expected.
I'm trying to return previously selected product options on the update page. These options have been previously inserted using a checkbox in a repeated table and the MRT on the insert page.
Jon CunninghamBeta Tester
To populate check boxes on your update page do the following:-
On the update, page, you set up the checkboxes the same way as on the insert page.
Create a recordset for your chosen table (the one that holds the data for the checkboxes) to return the chosen ID and name, and use a repeat region to write a checkbox for each available checkbox echoing the ID as the value and the name as the label.
Once you add the Manage relational table behavior, it will pre-populate the checkboxes based on the selections in the checkbox table.
Hope that this helps
Jonathon
bill3786
Thanks Jonathan
I have previously successfully created my insert, delete and update pages which add, delete and update data in the main products table and the linking productoptions table.
The problem I have occurs when I choose to update data from a results page, none of the previously selected checkbox options are populated. The data is in the tables but will not display in the checkboxes.
please send a copy of your page so we can examine the code.
bill3786
Here is the update page.
It will perform an update properly but wont populate the checkboxes from the database when selecting update from the results page.
A couple of other related questions.
1. I want to add the same option checkboxes to my search and detail pages. Do I run the MRT exactly as that for the update page using the WADAUpdateRecord key value in step 2 of the MRT and a different trigger on step 1
2. I can get the repeating table to work successfully on the insert page with the option checkboxes but it doesnt seem to work with an update page. Should the repeating table work on an update, search and detail pages? If so is the procedure different from an insert page?
bill3786
Hi, any update on this?
