SecurityAssist Not Working
Thread begun 6/29/2009 5:24 pm by michaelf0199272 | Last modified 6/30/2009 6:26 am by Ray Borduin | 1909 views | 1 replies |
michaelf0199272
I am using the Security Assist Wizard along with a Template. Everything seem to work fine until it begins to create the pages -- after creating the first page -- in the process of creating the second page, the whole process just hangs. When this happens, I had to kill\quit the dreamweaver.
I) Why does this thing hang when the pages are being created?
II) Why doesn't the cancel button ever worked?
Many thanks,
Michael
It is not behaving the way it should and I can't really diagnose why from the limited information provided.
I would try deleting the winfilecache .dat file with DW closed and see if that fixes it. If not, try it with a different template or no template to see if it is something about the template causing problems.
Once you have narrowed it down a little, post a support incident and/or post back here and I can try to analyze the symptoms or files involved for instance if we determine the template somehow is the cause.
