Dynamic Upload Folder
Thread begun 3/14/2011 5:34 am by jon392819 | Last modified 1/24/2012 2:08 pm by info97301 | 7139 views | 15 replies |
jon392819
I am about to build a dashboard for business owners to login to allowing them to create offers and discounts. I would like to use html editor as the wysiwyg as it will make it very easy for the non IT bussiness owner to create a nice looking offer. It will also make it easy for them to uload images.
However, is it possible in html editor to not have the upload folder hard coded, instead have it pick up a folder name from a session variable (created on login).
I do not want business owners to see other business owners images.
Any pointers greatfully receaved.
Jon
it will require hand editing the webassist/kfm/configuration.php file.
the lines that sets the upload folder location is:
$kfm_userfiles_address = '../../images/';
$kfm_userfiles_output = 'images/';
this sets the upload location to the images folder of my site, it may be diferant for your site.
you can add a session to the path by changing that to:
if(!session_id()) session_start();
$kfm_userfiles_address = '../../images/'.$_SESSION['userID'];
$kfm_userfiles_output = 'images/'.$_SESSION['userID'];
this is using a session named userID, you can change this to another session if you like.
bear in mind, that this is not a supported modification, you will need to be comfortable editing PHP to get this to work.
jon392819
Thats super Jason. Thanks for the solution and quick reply.
you're welcome.
info97301
Is it possible to have different folders for different areas/users?
For example, I would like the upload folder for 'site administrators' to be ../up/sites/$_SESION['SiteID']
but for users (members of that site) to be ../up/sites/$_SESSION['SiteID']/$_SESSION['MemID']
Images used for a different purpose would be stored in /up/top-pics/
etc etc
Can this be done? If not, could you put it on the wishlist for future releases?
Cheers
Chris
you would need to hand code the logic to dynamically set the upload folder based on your criteria
info97301
Hi JAson
In my configuratio.php file it has:
$kfm_userfiles_address = '../../up/sites/'.$S_SESSION['SiteID'];
$kfm_userfiles_output = rel2abs($kfm_userfiles_address,dirname(__FILE__));
I've changed the first line - what should the second line read - at the moment, uploads go to the 'up' folder, not up/#SiteID
A second issue I have is that when I try to enable security, it says I don nt have security assist andt tries to get me to buy a copy - even though it is installed on the page!
Cheers
Chris
the second line should not change, but you have a syntax error for the first l;line.
this code:
should be:
@session_start();
$kfm_userfiles_address = '../../up/sites/'.$_SESSION['SiteID'];
for the other issue, make sure to install the latest version of HTML Editor that is available from the download center.
info97301
Hi Jason
Still the same problem.
I got an email from you saying that a support ticket had been raised - but there's nothing in my support area.
Cheers
Chris
info97301
Hi Jason
Still no getting anywhere!
The configuration file is as below
Cheers
Chris
$startKFMDir = getcwd();
chdir(dirname(__FILE__));
require_once( "library.php" );
<?php require_once( "../../Connections/connRoSite.php" ); ?>
<?php //Security ?>
<?php chdir($startKFMDir); ?>
$kfm_hidden_sidebar = false;
if(isset($_GET['showsidebar']) && $_GET['showsidebar'] == 'false') {
$kfm_hidden_sidebar = true;
$kfm_db_type = 'mysql';
$kfm_db_prefix = 'kfm_';
$kfm_db_host = $hostname_connRoSite;
$kfm_db_name = $database_connRoSite;
$kfm_db_username = $username_connRoSite;
$kfm_db_password = $password_connRoSite;
$kfm_db_port = '';
$use_kfm_security = false;
$kfm_workdirectory = '.files-sqlite-pdo';
$kfm_imagemagick_path = '/usr/bin/cnvert';
$kfm_dont_send_metrics = 1;
$kfm_server_hours_offset = 1;
* This function is called in the admin area. To specify your own admin requirements or security, un-comment and edit this function
function kfm_admin_check(){
return false;
