Known Issue and Fix - Missing Toolbar items
Thread begun 3/01/2011 2:04 pm by Jason Byrnes | Last modified 9/04/2013 1:42 pm by Jason Byrnes | 13121 views | 19 replies |
If you notice missing toolbar items, you can replace them updating the admin_cms/contents_insert.php and admin_cms/contents_update.php pages. locate the following code:
$CKEditor_config["toolbar"] = array(
array( 'Source','DocProps','-','Save','NewPage','Preview','-','Templates'),
array( 'Cut','Copy','Paste','PasteText','PasteWord','-','Print','SpellCheck'),
array( 'Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'),
array( 'Form','Checkbox','Radio','TextField','Textarea','Select','Button','ImageButton','HiddenField'),
array( 'Image','Flash','Table','Rule','Smiley','SpecialChar','PageBreak'),
array( 'FitWindow','-','About'),
array( 'Bold','Italic','Underline','StrikeThrough','-','Subscript','Superscript'),
array( 'OrderedList','UnorderedList','-','Outdent','Indent'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyFull'),
array( 'Link','Unlink','Anchor'),
array( 'Style','FontFormat','FontName','FontSize'),
array( 'TextColor','BGColor'));
and replace it with:
array( 'Source','-','Save','NewPage','Preview','-','Templates'),
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','Print','SpellChecker','Scayt'),
array( 'BidiLtr','BidiRtl'),
array( 'Bold','Italic','Underline','Strike','-','Subscript','Superscript'),
array( 'NumberedList','BulletedList','-','Outdent','Indent','Blockquote','CreateDiv'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array( 'Image','Flash','Table','HorizontalRule','Smiley','SpecialChar','PageBreak'),
array( 'Styles','Format','Font','FontSize'),
array( 'TextColor','BGColor'),
array( 'Maximize','ShowBlocks','-','About'));
gzirfas374932
Toolbar items, Now how about CSS?
Got my 'Styles' on the toolbar item. In the PowerCMS, which uses the old FCKeditor, I have linked my styles to the style menu and the CSS renders in the editor window. How do I accomplish this same feat in CMS Builder???
see this post for details:
showpost.php?p=91818&postcount=10
MarkNewsom
Next Release Date?
When will this be fixed and available for download as a new release?
you asked this question in another thread as well:
showthread.php?t=19726
see my reply there.
Web Designer Troy
Misspelling in CKEditor Toolbar Array
This post has been deleted.
newlifefromgod427360
tool set
Is this correct done in the power cms database or in the site itself? The site code appears that it does not contain this code, I would believe that it is required to find it on my pc? All of the edit functions reported the error that I mentioned in the admin. thanks Ken.
tool set
Thank Jason. However, this code does not exist in my site. in the contents_insert there is one line of code. <?php header('Location: index.php'); ?>, in the contents_indext there is only one mention of array listed, var optionArray = new Array();
<?php if ($totalRows_WAGroups>0) do { ?>
optionArray[optionArray.length] = "<?php echo str_replace("<", "&lt;", $row_WAGroups['ContentGroup']); ?>";
<?php } while ($row_WAGroups = mysql_fetch_assoc($WAGroups)); ?>
//--> Now this is part of the super suite purchased 6/17/2011. Using dreamweaver cs4. Perhaps there is another bug that is java script in one of the supporting programs that requires attention also? Maybe form builder. I apoligize for not knowing the proper venue for all this, but had no idea I was going spend so much time trying to marry this software up to adobe, when I found it advertised on adobe. Thank-you Ken.
toms016390756
Was this resolved?
