Where have the heading tags gone (Urgent)
Thread begun 2/24/2011 7:22 am by gary375937 | Last modified 6/14/2011 12:20 pm by neilo | 9740 views | 8 replies |
gary375937
Hi Everyone
I was hoping someone could help with the nightmare I am having at the moment. I am building a site around Power CMS and the editor appears to have changed both visually and the functionality.
For example I can no longer access the h1, h2, h3 tags etc
This is a problem as although I can manually write them in I can't expect my client to do this, has anyone any ideas as to how I can make my old editor come back as this is causing me serious problems.
Could this be something to do with me originally trying to do the site with CMS builder?
Thank you for any help you can offer me
Cheers
Gary
It appears the default toolbar doesn't include all of the available options. You could edit it with the new html editor, or you could do a simple update in the associated pages.
You'll find a line that refers to:
$CKEditor_config["toolbar"]
You can add or remove toolbar options manually from the array built on that line.
All of the options appear here:
$CKEditor_config["toolbar"] = array(
array( 'Source','-','Save','NewPage','Preview','-','Templates'),
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','Print','SpellChecker','Scayt'),
array( 'Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'),
array( 'Form','Checkbox','Radio','TextField','Textarea','Select','Button','ImageButton','HiddenField'),
array( 'BidiLtr','BidiRtl'),
array( 'Bold','Italic','Underline','Strike','-','Subscript','Superscript'),
array( 'NumberedList','BulletedList','-','Outdent','Indent','Blockquote','CreateDiv'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array( 'Link','Unlink','Anchor'),
array( 'Image','Flash','Table','HorizontalRule','Smiley','SpecialChar','PageBreak'),
array( 'Styles','Format','Font','FontSize'),
array( 'TextColor','BGColor'),
array( 'Maximize','ShowBlocks','-','About'));
It looks like we didn't properly update all of the toolbar options since some of the names have been changed... it is supposed to have those listed... we'll get that updated... the default should probably be:
array( 'Source','DocProps','-','Preview'),
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','SpellChecker'),
array( 'Image','Flash','Table','HorizontalRule','Smiley', 'SpecialChar','PageBreak'),
array( 'Format','Font','FontSize'),
array( 'Maximize','ShowBlocks'));
gary375937
Still not working
Hi Ray
What is the array or h1, h2, h3 though mate as this did not work
Cheers
Gary
The heading tags are in the: 'Format' select list... they should be included.
gary375937
Format Select List?
Hi Ray
I have no idea what you mean by Format Select List. I have changed the code as suggested and can not see any way of adding my heading tags, can you please let me know exactly what I need to do to get this working as I have three sites to get finished over the next 4 days that all require this facility.
Cheers
Gary
Please post a url or screen shot of the current editor and I can try to determine the issue.
gary375937
Hi Ray
Please see attached
Cheers
Gary
I have opened up a support incident so that I can look into this issue with you over the phone. Please update that incident with a good phone number to reach you and I'll give you a call and help you debug this issue.
neilo
It was also a real bugger to have to work out that the array containing styles should contain 'Styles' and not 'Style' as per WA supplied!
array( 'Style','FontFormat','FontName','FontSize'),
That from a fresh download.
Why can't WA update the downloadables when errors are reported? Just a thought. Not disputing that time spent making validation tooltips wasn't time well-spent, but it's nice to get the engine running before you fiddle with the indicators.
