Super Suite eCart not adding item to or showing Shopping Cart
Thread begun 3/15/2009 2:49 pm by mikec156913 | Last modified 2/26/2010 5:07 pm by Jason Byrnes | 9710 views | 30 replies |
mikec156913
Hi All,
My eCart (v4.1.5) is not adding the chosen item to the shopping cart or displaying the cart after the Add button is clicked. I have set up the Add to Cart redirect to display the shopping cart affter Add.
I can access the shopping cart from a display shopping cart menu option but it's empty!
Any ideas please?
Mike.
mikec156913
Problem sorted...
Mike
info271221
eCart always showing empty cart
<Link removed> - can you help?
Use the attached page to test your host to see if session management is working properly.
info271221
session test results
I believe it is working properly.
<Link removed>
Thanks!
On the pages with an add to cart button, look for code similar to the following near the doctype tag:
// WA eCart Redirect
if ($<Your cart Name>->redirStr != "")     {
header("Location: ".$<Your cart Name>->redirStr);
and change it to:
session_commit();
info271221
cart display all buttons work except checkout
Okay. So that fixed the main add to cart page (and I have recorded that for future use)
and now I'm on the cart display page...
<Link removed> - Everything on this page functions except the checkout button.
Thanks for your help!
In the server behaviors list, double click the Checkout Server Behavior to set the redirect to go to the checkout page.
info271221
Wow - Thanks!
I should have thought of that. Thank You! Is their a way we can leave this post online; however delete our website links?
Thanks again!
Links have been removed.
