Local testing login and registration pages
Thread begun 2/22/2011 12:51 pm by sunsabbath76401977 | Last modified 2/23/2011 8:38 am by Jason Byrnes | 5090 views | 8 replies |
sunsabbath76401977Beta Tester
I there anyone who can help with my local testing server as it will not open stream.
Warning: require_once(Connections/db345740447.php) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\pizzapal.co.uk\users_LogIn.php on line 2
Fatal error: require_once() [function.require]: Failed opening required 'Connections/db345740447.php' (include_path='.;C:\xampp\php\PEAR') in C:\xampp\htdocs\pizzapal.co.uk\users_LogIn.php on line 2
I do not know what a stream is?
Same thing happens on the registration page.
Warning: require_once(Connections/db345740447.php) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\pizzapal.co.uk\users_Registration.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'Connections/db345740447.php' (include_path='.;C:\xampp\php\PEAR') in C:\xampp\htdocs\pizzapal.co.uk\users_Registration.php on line 1
Is this problem connected to the connections folder, file in Dreamweaver?
Got to go out now, so any reply will be in an hour.
Thanks for reading
Sabby76
the error is saying that it cannot opren the Connections/db345740447.php file
send a copy of the users_LogIn.php file so i can look at the code.
it looks like it is trying to locate the connections file at:
C:\xampp\htdocs\pizzapal.co.uk\Connections\db345740447.php
Does that file exist at that location?
Connections file
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_local = "localhost";
$database_local = "db345740447";
$username_local = "root";
$password_local = "9fk58fjk49de";
$local = mysql_pconnect($hostname_local, $username_local, $password_local) or trigger_error(mysql_error(),E_USER_ERROR);
i dont need the connections file.
can you send a copy of the login page in a zip archive.
also:
C:\xampp\htdocs\pizzapal.co.uk\Connections\db34574 0447.php
User Login php file
Please see attached zip file, thank you.
you are not answering this question:
also:
Edit/Delete Message
Delay
Had to install winzip...
The file is called local.php in the connections folder.
I will change it over now...
Sabby76
Bingo
Thank you Jason
What ever part of XAMMP runs the file, please which part is it?
Sabby76
Create a new database connection and name it "db345740447" set it to connect to the database on your local xampp server. This is the connection name that the login page is looking for, it is giving the error because there is no connection with that name in the connections folder.
