Trying to visually separate data output, that should not show, if data field is empty
Thread begun 2/19/2011 12:07 pm by Roxana | Last modified 2/24/2011 12:22 pm by Jason Byrnes | 7055 views | 13 replies |
Roxana
This is not really a Dreamweaver question, but maybe someone could help me, so here it goes:
I have an online shop with catalogue and detail pages. The products offered consist of up to five components. Each of these components has its own data field. On the detail page they are listed in a column. On the catalogue page I do not want to waste vertical space and therefore list them separated by commas (this is how it used to be, until I split up the contents in different data fields to be able to list them in a column on the detail page).
So, when I insert a comma between the data fields, not as a surprise these commas will show up also for products, that have less than 5 components. This looks especially silly for products that don't list any components (5 commas in a row).
I tried forced space (with option+space), but the separation still does not look good.
Is there a way to maybe include the comma into the data set, or have a comma only be visible, if the following data field is not empty?
Roxana
I tried this: <?php echo ","; echo $row_Recordset1['contents5']; ?>
But this will also show the comma, if the data field is empty.
Roxana
Solution found :)
I just found the solution:
<?php if (!empty($row_Recordset1['contents2'])) echo ","; ?>
where the following field is <?php echo $row_Recordset1['contents2']; ?>
This way the comma will only show, if there is an entry in contents2. Same for all fields up to contents5.
Roxana
Encouraged by my find, I now try to have a select menu not show, if the recordset is empty.
The menu disappears just like it should, but when I put that item in the cart, the item no. is missing, the price is zero. Only the description and quantity is passed on.
This is the code for he select menu with show if:
<?php if (!empty($row_rssizedefault['size'])) { // Show if recordset not empty ?>
<select name="SelectSize" id="SelectSize" onchange="showprice()">
do {
<option value="<?php echo $row_rssizedefault['size_id']?>"<?php if (!(strcmp($row_rssizedefault['size_id'], $row_rssize['size']))) {echo "selected=\"selected\"";} ?>><?php echo $row_rssizedefault['size']?></option>
} while ($row_rssizedefault = mysql_fetch_assoc($rssizedefault));
$rows = mysql_num_rows($rssizedefault);
if($rows > 0) {
mysql_data_seek($rssizedefault, 0);
$row_rssizedefault = mysql_fetch_assoc($rssizedefault);
</select>
<?php } // Show if recordset not empty ?>
The same happens, when I use this code as the first line instead:
or <?php if ($totalRows_rssizedefault == 0) { // Show if recordset empty ?>
Does anyone know, what I have to change to make it work?
imposible to tell what is wrong without seeing how the add to cart button is configured.
send a copy of your page please so i can look at the code.
Roxana
Hi Jason,
Thank you for your help. I attached the detail page. It happens to be the same page, that I attached in the other thread.
The code you are looking for is from line 660 to 699.
in the add to cart button, you have the Price, Article, version and size column set to get their values from the rspricelookup recordset.
the rspricelookup recordset relies on values from the SelectSize and SelectVersion form elements.
You would need to create another recordset that will return the correct price for items that do not have a size or version option and edit the add to cart code to use this recordset value instead.
$ATC_itemPrice = floatval(($row_rspricelookup['price']!=""?$row_rspricelookup['price']:$row_rspriceNoSize['price']);// column binding
Roxana
Almost there
Hi Jason,
Thank you for the code. I now understand, why the price and item no. weren't posted to the cart page. I used the same code for the item no..
In our situation, we have items without size and version option (for which the code worked just fine), but also items with size option and no version option, or the other way around.
I tried the code individually on each type of item, and it worked, but when I try to make it work for all items at the same time, then I have a PHP error (blank page). This is mainly, because I don't know how to put the code in sequence (I have no background knowledge of PHP).
What I am trying to tell the computer is: use rspricelookup, if there is no size info use rspriceNoSize, if there is no version info use rspriceNoVersion, if there is neither size nor version info use rsNoVersionNoSize.
The recordsets are tested and work.
This is what I tried as a first step, just to use rspriceNoVersionNoSize if rspriceNoSize does not return a price.
$ATC_itemPrice = floatval(($row_rspricelookup['price']!="")$row_rspricelookup['price']:$row_rspriceNoSize['price'])?$row_rspriceNoSize['price']:$row_rspriceNoVersionNoSize['price']);// column binding
try using this code:
$ATC_itemPrice = floatval(($row_rspricelookup['price']!="")?$row_rspricelookup['price']:(($row_rspriceNoSize['price']!="")?$row_rspriceNoSize['price']:$row_rspriceNoVersionNoSize['price']));// column binding
Roxana
Thanks Jason,
I followed your lead and extended the code to also handle products with no version option, to pass on price and item no..
$ATC_itemPrice = floatval(($row_rspricelookup['price']!="")?$row_rspricelookup['price']:($row_rspriceNoSize['price']!=""?$row_rspriceNoSize['price']:($row_rspriceNoVersion['price']!=""?$row_rspriceNoVersion['price']:$row_rspriceNoVersionNoSize['price'])));// column binding
$ATC_itemarticle = "".$row_rspricelookup['item_no_long'] .""?$row_rspricelookup['item_no_long']:($row_rspriceNoSize['item_no_long']!=""?$row_rspriceNoSize['item_no_long']:($row_rspriceNoVersion['item_no_long']!=""?$row_rspriceNoVersion['item_no_long']:$row_rspriceNoVersionNoSize['item_no_long']));// column binding
It looks like it is working, but when I choose a certain size option and put it in the cart (that works), then I cannot choose another option of the same product. If I do so, the detail page will post the same as the first chosen option with that same price (the wrong price) regardless of my choice.
Your help already goes way beyond regular support, so please let me know, if you cannot help me any further from this point on.
