"To" properties not sticking
Thread began 2/15/2011 7:59 pm by Lee Firth | Last modified 7/15/2011 11:08 am by Dennis | 2184 views | 5 replies |
Lee Firth
When I edit the advanced settings for the "To" field, I add a "Recordset loop" (see attached image1.jpg) but if I save this and then go back into the advanced settings again it displays as a "From file" type (see attached image2.jpg)
Lee Firth
It seems that this is a bug.
After following the instructions on this post:
showpost.php?p=89443&postcount=4
It fixed the problem, but if you open the dialogue box to edit other areas it overwrites your changes and you have to manually edit the code again.
This also fixed my other issue with the progress bar.
Yes, this has been logged in our bugbase and will be corrected in the next update to CSS form Builder 2.
Dennis
New build yet?
Has there been any updates or a new build to correct this problem.
I am having this problem and it is a major inconvenience. I am just learning UE and constantly opening the Server Behavior to make small tweaks, every time I loose the setting.
Dennis
Dennis
Thanks Jason,
Dennis
