Pro Maps 1.05
Thread begun 6/25/2009 7:10 pm by Nuno | Last modified 7/01/2009 7:27 am by Ray Borduin | 3190 views | 3 replies |
Nuno
Pro Maps 1.05
Can you tell me how to fix the partial view of the Map?
See here: wcmap.asp
Best regards,
Raul
What do you mean by partial view? What browser are you using? I don't really understand the exact issue you are referring to.
Nuno
See copy here
See how I see it map_view.pdf
Best regards,
Raul
I don't believe you can fix that problem. It appears to be an issue with the google API on IE6 and IE7 when centering on that point. You will see if you drag the map around it will show and then if you drag it back to center the gap will appear but it doesn't have problems in IE8 or FF. I'm pretty sure there is nothing you could really do to fix it on IE6 and IE7 short of center on a different point where the problem does not occur.
