updating connections in localhost.php
Thread begun 6/23/2009 7:59 pm by berndrendic374326 | Last modified 6/24/2009 9:08 am by berndrendic374326 | 4774 views | 2 replies |
berndrendic374326
hey guys I have finally managed to create database etc but i am now having problems with updating conections in localhost php part ... ok here is the code , can someone tell me what am i suposed to put here...
i am on wamp server doing it localy and normally i test my site on localhost/
so do i type localhost in $hostname_localhost line
what about $database_localhost? is that the name i gave to my database in myadmin php?
and $username_localhost whats that?
is that the admin name i put in wa globals in line 24? or something else
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_localhost = "localhost";
$database_localhost = "";
$username_localhost = "";
$password_localhost = "";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
I keep getting this error msg ;
Warning: mysql_pconnect() [function.mysql-pconnect]: Access denied for user 'ODBC'@'localhost' (using password: NO) in C:\wamp\www\hfsss\Connections\localhost.php on line 9
thanks in advance
you need to have a value for your database name username and password. Those can't be left blank.
berndrendic374326
Thanks for reply i Ve got it working ...
if you use User reg park as it is without re-naming anything in it then this is what works for me ;
$database_localhost = "mysql";
$username_localhost = "root";
and password .... not needed to get it run
