problem with passing session variable from cart
Thread begun 3/14/2009 8:01 pm by contact341526 | Last modified 3/16/2009 4:03 pm by contact341526 | 2613 views | 2 replies |
contact341526
Hello, I have my information from my confirm page sending to my database. Then as the visitor clicks submit order the the success page shows up and behind the scenes a php xml pages is being created and submitted to a fulfillment company. That all works fine. However I need to filter recordsets on the page that creates the xml.
Right now anyone can go to that url and see the last posted order(containing all of the shipping, and order information). I need this page to come up blank and figured I should do this with a recordset filter. However, I have tried everything. I can not do a form or url filter - I am thinking I need to do a session variable filter - but I get blank results when I do that. Maybe someone has an idea or code that can help me out. Below is an example of what I have currently.
Top of Page
Not sure if I needed this one - but figured this wold specifically pull in the last name variable - which is just one example of what I could filter by
if($_SERVER["REQUEST_METHOD"] == "POST") {
$_SESSION["eCartCheckoutForm_lastname"] = "".((isset($_POST["lastname"]))?$_POST["lastname"]:"") ."";
Here is the where query
mysql_select_db($database_tconnect, $tconnect);
$query_rsxmlorders = sprintf("SELECT * FROM order_detail WHERE billlname = %s ORDER BY `date` DESC", GetSQLValueString($colname_rsxmlorders, "text"));
$rsxmlorders = mysql_query($query_rsxmlorders, $tconnect) or die(mysql_error());
$row_rsxmlorders = mysql_fetch_assoc($rsxmlorders);
$totalRows_rsxmlorders = mysql_num_rows($rsxmlorders);
Here is what is actually entered in for the variable to filter by
$_SESSION['eCartCheckoutForm_lastname']
I get completely blank results when I do this.
Thank you for any help that you may be able to provide.
Looks like you need to debug a little... add:
die($query_rsxmlorders);
That should tell you why the RS is empty... are you adding the recordset AFTER the insert details in database server behavior? If the records haven't been inserted yet, then the RS would be empty.
contact341526
not sure
I guess that does not make much sense to me. The records are in the database and I can get them to display, but I need to apply a filter using the session so that anyone the finds that page outside of the session will see it as empty.
Right now anyone who goes to that page from any browser will see information regarding the last order that was placed.
when I choose to filter by session I get a blank page, even when I am still in the session - that is the problem. Hopefully that makes more sense.
thanks
