SQL for last month
Thread begun 1/05/2011 7:18 am by Daryl | Last modified 3/30/2011 5:18 am by Daryl | 4012 views | 9 replies |
DarylBeta Tester
SQL for last month
I am using the following query to find records for last month
SELECT * FROM application JOIN company JOIN users WHERE YEAR(application.application_date) = YEAR(CURDATE()) AND MONTH(application.application_date) = MONTH(CURDATE())-1 AND application.consultant_company = company.co_id AND application.consultant= users.id ORDER BY application.application_date DESC
However this does not work this month for last month. Any idea why and what I should change the sql too to get it to work?
That is because you are using:
MONTH(CURDATE())-1
and this being month 1, then that would look for a return value of month 0, when you actually want month 12.
Instead try:
MONTH(CURDATE() - INTERVAL 1 MONTH)
DarylBeta Tester
Thanks Ray
But this doesn't show results from December 2010 either.
That is because you would also have to use:
YEAR(application.application_date) = YEAR(CURDATE() - INTERVAL 1 MONTH)
DarylBeta Tester
Thanks Ray!!
Would
YEAR(CURDATE() - INTERVAL 2 MONTH)
show data from 2 months ago?
yes it would.
DarylBeta Tester
Excellent!
Thanks again!
DarylBeta Tester
What is the best code for PHP to do the same?
I am using;
For this month
<?php $date date('F'); echo "$date";?>
For 1 month ago
$mnth
date('F');
$prev_mnth date('F',strtotime("-1 months")); // "previous month" works also
echo $prev_mnth;
But they are both showing March today
For 2 months ago
$mnth
date('F');
$prev_mnth date('F',strtotime("-2 months")); // "previous month" works also
echo $prev_mnth;
But this shows January as expected...
DarylBeta Tester
This solution shows March instead of February too...
$last_month_time
mktime(000date("m")-1date("d"),   date("Y"));
$last_month date('F'$last_month_time);
echo
"$last_month";
DarylBeta Tester
This one works!
<?php echo date('F'mktime(000date('m')-11date('Y')));
