Max upload size
Thread begun 6/21/2009 1:25 pm by twebb290214 | Last modified 9/24/2009 10:44 am by pau376010 | 18214 views | 32 replies |
twebb290214
Max upload size
hi, i'm thinking of upgrading to DFP2
does it rely on the pnp.ini for the max upload size?
my provider sets this at 8mb which is not enough for me as i'm uploading seromons on mp3 up to 20mb
can DFP2 do this?
Tom
Travis250923
DFP is only limited to what is in the php.ini file. If that is too low I believe there might be a work around using htaccess.
uploading-larger-files-in-php.html
Never tried it but others here may have more info.
DFP cannot override the server settings set by your ISP when it comes to uploads.
meister281653
Where can I in put the maximum size of the image that can be uploaded?
This was nice in DFP1
Cheers
Denis
Now you would use WA Validation toolkit server validation to validate the size as an integer.
meister281653
ok, which validation type is that? interger? i cant find that.
Denis
Integer validation. Then use the binding for the file size of the upload. I believe it is returned in bytes.
meister281653
I cant find INTEGER, is it NUMBER? If its number it doesnt work :-(
trigger is button
validation type is number
server variable is $_FILES["fileField"]
please a documentation, same for SIZE (width & height) :-)
Should be number validation. You would apply it twice... once for width and once for height. Width and height should be available separately in the form binding.
meister281653
PLEASE!
show me how to do it.
WHAT is the TRIGGER?
Why was this delete in the DFP2??????
I need check filesize, width height.
What trigger? Button or something else? cause i think i only can be checkt if its uploaded.
why was it deleted from DFP2? this ist really a step back.
PLEASE, I need documentation how to do that with DFP2 and VTK.
File Size, Width, Height.
The BUTTON trigger couldnt be, cause it setzt the validation before the upload.
I need trigger, IF UPLOAD is ok, THEN check the 3 things.
Please make an update for VTK, that would be cool.
this makes no sence. alwys double work!
I need HELP,
thanks
Denis
