Auto Login Option Cookies Toolkit and Security Assist Wizard
Thread begun 12/27/2010 12:50 pm by dlovas275157 | Last modified 12/28/2010 7:39 am by Ray Borduin | 2778 views | 3 replies |
dlovas275157
I have generated my login page with SA Wizard and made adjustments to the Auth User SB's to work with encrypted passwords. I have also "checked" the options "remember me" and "auto login" when running the SA Wizard.
My "Remember Me" works fine, however the "Auto Login" does NOT work. And I cannot find any help docs on making the auto login option work.
I assume the auto login is supposed to check the stored values in the form and then auto-submit the form. But can't find a tutorial on this anywhere.
Attached is my login page code.
Any help is appreciated. - D
You have a bunch of repeated recordset includes, you can delete all but one of those.
Auto Login should work based on the code that I see. Is there a sample url where I can test it? Maybe the problem is with setting the cookies in the first place.
It doesn't auto-submit the form, it checks to see if the cookies are set and automatically logs in and redirects before the form is even created when it functions properly.
dlovas275157
Ray,
The repeated recordset includes do not appear to be the cause of the auto-login not working. They have been removed, but it still does not work.
I do have a live working example, but would prefer to post in a private message, then I could also provide you a login email/password to work with.
D
I have created a support incident so that you can post login information privately. Please update that incident with information on connecting and viewing the problem directly.
