godaddy websiteprotection scan alert
Thread begun 12/15/2010 9:08 am by lk412779 | Last modified 12/21/2010 5:02 pm by Ray Borduin | 5772 views | 10 replies |
lk412779
my site is hosted on godaddy and the websiteprotection service they offer alerted me to several apparent sql syntax errors that could lead to injection attacks. I've tried several searches here for pertinent info, but have not found anything to help-so sorry in advance if i have missed something obvious. Ive attached the report that the website scanner generated.
I would like to know what changes to the code are necessary to make the site more secure.
here is the code i think it is referencing:
<div class="cartwrapper">
<div class="atcdiv">
<form name="eCart1_1_ATC_3" method="POST" action="/testinfo.php?testid=3" >
<input type="hidden" name="eCart1_1_ID_Add" value="3" >
<input type="text" name="eCart1_1_Quantity_Add" value="1" size="4" >
<input type="submit" class="eC_FormButton" value="Add to Cart" name="eCart1_1_ATC">
</form>
</div>
<div class="vcdiv">
<form name="eCart1_View_form_1" method="POST" action="/testinfo.php?testid=3">
<input name="eCart1_View_1" type="button" class="eC_FormButton" onClick="MM_goToURL('plugins/parent','eCart/')" value="View Cart">
</form>
</div>
</div>
More info:
Also my database tables that contain username, usermail and usermessage (i have a webassist contact form) are getting spammed with things such as <script>alert(42);</script> (which is code that i recognize from the alert i have attached)-
i should say that the input form is not on the page that contains the eCart buttons. Hope any of this info is helping...
please send a copy of your testinfo.php page so I can examine the code.
lk412779
Here is the testinfo.php page
i need a copy of the actual php page. the file you sent seams to be the browser source? I need to see the code on the php page, not the source after it has been processed by the server and rendered in a browser.
lk412779
oops, here it tis
part of the problem is in hand coding the where clause for the recordset rather than using Dreamweaver to create the filter.
change:
$testid=$_GET['testid'];
to:
$testid=intval($_GET['testid']);
then look for the following code, you will find it twice:
 action="<?php echo $_SERVER["PHP_SELF"]; echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""?>"
and change it to:
 action="<?php echo $_SERVER["PHP_SELF"]; echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".str_replace("\"""&quote;"str_replace(">""&gt;"str_replace("<""&lt;"$_SERVER["QUERY_STRING"]))):""?>"
lk412779
Thank you very much for the help Jason, the last scan looked better. I am still having an issue with some of my "simple contact form" fields in my database getting populated with spam so i think i'm going to spend a day doing some reading/learning on this stuff before i go any further. I'll be back!
lk412779
Ok, I have posted in the validation section regarding the spam issue but i am still uncertain regarding the way to use Dreamweaver to correctly filter the where clause. I think i understand that by using intval that only values that are passed that are integers will be accepted and i can see that this would be better than a page accepting any string (such as sql code), is there a better way to pass or declare the variable $testid so that i can still have a dynamic page that is fairly secure? If this is an elementary question, plz forgive me, not lookin for a handout, really just looking for a nudge in the right direction :). thanks again-
Use the built in techique of adding parameters to the sql statement. It will automatically add code to prevent sql injection.
lk412779
ok, after removing our original fix and using the advanced recordset dialog from the bindings tab in DW the result is a change from
mysql_select_db($database_mysqlconnection, $mysqlconnection);
$query_Recordset1 = "SELECT * FROM products WHERE ProductID=$testid";
to
$testid_Recordset1 = "1";
if (isset($_GET['testid'])) {
$testid_Recordset1 = (get_magic_quotes_gpc()) ? $_GET['testid'] : addslashes($_GET['testid']);
$query_Recordset1 = sprintf("SELECT * FROM products WHERE ProductID=%s", GetSQLValueString($testid_Recordset1, "int"));
This is what you meant YES?
