CSS FormBuilder - errors
Thread begun 12/09/2010 11:35 pm by kurt76739 | Last modified 1/18/2011 7:49 pm by peacehawk | 8963 views | 17 replies |
kurt76739
Hi
I tried to insert a form to a page in my homepage.
If I click FINISH in my CSS FormBuilder 2 window
I get allways error messages (see attachments).
At first I got a lot of javascript errors - these I could eleminate
in deleting the DW-cache. But the "buildColumn" errors perist.
I tried to insert the form in a blank PHP-page - same errors.
What can I do?
Thank you for your help.
Kurt
t297098
Same errors
I m getting same errors
"Error generating:buildFieldGroup
TypeError:ShowIfObj.setParams is not a function"
PS
Using CSS form builder 2.0.0 in DW CS4
biesheuvel378713
CSS Form builder 2 worked okay until today.
When I'm finished designing and want to put the form on the page I get this message:
Error generating: buildfieldgroup
Type Error: ShowIfObject.setParams is not a function
Then I have to keep clicking through a lot of errors and the page have been partly build?
I've deïnstalled CSS Form builder and delete the winfilecache file and the reïnstalled the extension. But no succes?
I also got form toolkit installed?
see this thread for a fix to the issue:
showpost.php?p=82401&postcount=2
t297098
Not fixed
Replaced js file but now getting this
"Unable to open script file C\:Program Files\Adobe\Adobe DreamweaverCS4\Configuration\Shared\Webassist\FormValidations\WAFV_SSVariables_SB.js"(error3)
t297098
Ok done
Originally Said By: t297098
Had "Form Toolkit" deactivated. I activated and now seems to work.
Thank you.
OK, glad to hear it is working.
kurt76739
new errors
Hi
thank you for your help - Formbuilder works now,
except I go 3 new error-messages now (see attachment)
about a missing dwscript.js file.
On my whole PC there is no such file.
How do I get that?
Kurt
anonymous
Hi Kurt,
Sometimes those have to do with a saved layout or workspace but something has either changed or is not the same as when you saved the workspace. A lot of times, you can reset your workspace to one of the defaults layouts and that clears it up.
Best regards,
Brian
kurt76739
another one
Hi
thanks for the help - it did help to a certain point.
Now I get an JS-error about not finding FormValidation.
I did install the Formbuilder-extension anew - same result.
I'm a little disappointed about all that -
I thout I got an easy way to insert a form in my sites
but have to clear this an reset that an can't get the job done.
Thank you for help
Kurt
