reCAPTCHA with Universal Email 4
Thread begun 12/03/2010 8:02 am by lwade-bahr409715 | Last modified 12/27/2010 10:13 am by Ray Borduin | 19540 views | 42 replies |
lwade-bahr409715
I have created a form and am trying to use reCAPTCHA with UE4. When the form is submitted, the page displayed is the verify.php page from reCAPTCHA not the ThankYou.htm page I have specified in UE4. It is also not processing the email. -- Have you seen this before and can you please offer advice on a fix? Thank you!
all of the form processing code must be on the forms action page.
if the forms action is set to post to the verify.php page, the universal email will need to be on that page as well.
lwade-bahr409715
Thanks for the quick reply. I added the code to the Verify.php file and the behavior is the same.
what trigger did you use? Make sure not to use the Currant page submit trigger.
to be honest, I've never used recaptcha so i cannot saw whether it will work or not.
lwade-bahr409715
I did use the submit trigger. What trigger should I use instead? (reCAPTCHA is what is being used in this forum).
use the any form post trigger
This form may use reCapcha, but it was created by vBulletin, not WebAssist.
I am not familiar with the work flow of applying recaptcha, that is why i cannot say if it will work or not.
I _can_ say that universal Email will work with the captcha that is available as part pf form toolkit though.
lwade-bahr409715
Can you tell me how to change the trigger in the code? (Sorry, but I am new to PHP) I would like to try that before changing. Form Toolkit was not part of the Super Suite purchase and I would prefer to not spend the money at this point if possible.
send me a copy of the page and I will tell you what needs to be changed.
lwade-bahr409715
Thanks so much! I have zipped the contact form and verify.php file. As I mentioned, I did not originally have the code in the verify.php file until you said I should add it.
I appreciate your help!
OK, so the code in the verify page that performs the recaptcha is this:
require_once('recaptchalib.php');
$privatekey = "6LfkSb8SAAAAAFTdEqxOh88xq0KGh2xovD9nq1mA";
$resp = recaptcha_check_answer ($privatekey,
$_SERVER["REMOTE_ADDR"],
$_POST["recaptcha_challenge_field"],
$_POST["recaptcha_response_field"]);
if (!
$resp->is_valid) {
// What happens when the CAPTCHA was entered incorrectly
die ("The reCAPTCHA wasn't entered correctly. Go back and try it again." .          "(reCAPTCHA said: " . $resp->error . ")");
   } else {
$GoToPage = "ThankYou.htm";
the universal email code needs to replace the the:
so the full code for the verify page should be:
<?php require_once("webassist/email/mail_php.php"); ?>
require_once("webassist/email/mailformatting_php.php"); ?>
if (!isset($_SESSION))session_start();
if (!
$resp->is_valid) {
} else {
//WA Universal Email object="mail"
set_time_limit(0);
$EmailRef = "waue_Contact_Us_4";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "contactus@imfgsol.com";
$RecipArray[$CurIndex ][] = "jerry.bahr@imfgsol.com";
$RecipArray[$CurIndex ][] = "randy.bahr@imfgsol.com";
$RecipArray[$CurIndex ][] = "lwade-bahr@comcast.net";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
  if (
$TimeRemaining < ($TotalEmails*$RealWait) )  {
$TimeRemaining = $TotalEmails*$RealWait;
$_SESSION[$EmailRef."_Total"] = $TotalEmails;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = $TimeRemaining;
  while (
$RecipIndex < sizeof($RecipArray))  {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
    while ((
$EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
      if (
$EnteredValue)  {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
      }  else  {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
      if (
$AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
      if (
$TimeRemaining < ($EmailsRemaining*$RealWait) )  {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
session_commit();
session_start();
$_SESSION[$EmailRef."_Index"] = $LoopCount;
$_SESSION[$EmailRef."_Remaining"] = round($TimeRemaining);
session_commit();
wa_sleep($WaitTime);
      include(
"webassist/email/waue_Contact_Us_4.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
      if (
$LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex]))  {
$TimePassed = (time() - $StartBurst);
        if (
$TimePassed < ($BurstTime*60))  {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
        else  {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
      if (!
$EnteredValue)  {
$RecipArray[$RecipIndex][0] =  mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
  if (
$GoToPage!="")     {
header("Location: ".$GoToPage);
