Images show but the design is wrong when I create a gallery
Thread begun 11/24/2010 12:56 pm by jon392819 | Last modified 7/17/2012 8:41 am by Jason Byrnes | 12084 views | 8 replies |
jon392819
Hi Guys,
When I embed a gallery into a PHP page on my site it looks like the CSS and Javascript files are not been referenced right. The PG root folder is missing in the src to the css and javascript. In its place is the name of the parent folder holding the file containing the embeded code.
Dani Chankhour
That is correct, the latest dot release of PowerGallery does not store the site root in the database to make it more dynamic.
Can you send me a link where i can see the issue you are referring to?
jon392819
Thanks Dani,
Photocms is the install folder.
Link below:
mums/
Embed code: <?php
$pg_id = '1';
$pg_theme = 'light';
include('/usr/local/pem/vhosts/107626/webspace/httpdocs/photocms/galleries/ribbon_fullsize_lightbox/index.php');
JOn
neilo
Dani, Hi,
This is a recurring problem with this issue of PowerGallery. At the moment there are a couple of open tickets awaiting resolution, with more queries coming in daily.
This issue needs taking back to the bench with a view to a definitive dot release issue.
Dani Chankhour
Thanks. I can see the issue. This looks like a bug in PowerGallery since the page that includes the gallery is out side of the PowerGallery install folder. I have logged a bug in our bug base to fix the issue in future dot releases.
meanwhile i have attached a global.php which fix your issue, please download and replace your global.php under the galleries folder with the attached file.
jon392819
Thank you Dani. Works fine now.
J
ChrisW
Same issue
138205 ticket number
tattoo-artist-greg.php click tattoos
I repeated a few steps along (see ticket#) with replacing the library file and Im stuck. I also made the change to line 35 of global as instructed by jason. Any help would be great.
design343795
Still haveing issues Internal error Power Gallery
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@imagesbygb.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8e-fips-rhel5 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 Server at www.imagesbygb.com Port 80
any advice Also we have another gallery that showed the wrong link to copy and this one has all sorts of errors we are fully reloading that one agin again agin but still errors at one point god a kind of gallery up without fomating such as the display galery want there just the imahes with line errors such as line 370 line 227 or the line so we will will address that one shortly but need advce on this error above first
you reported the issue in another thread as well, see my replay there:
showthread.php?p=132955&posted=1#post132955
mds119803
This post has been deleted.
