coding error
Thread begun 3/13/2009 9:42 am by roy.chappell355352 | Last modified 3/13/2009 10:11 am by Ray Borduin | 2896 views | 1 replies |
roy.chappell355352
coding error
Hi
I believe CSS Sculptor outputs some wrong code
look here in IE6
temp/
This is a straight out of the box 2 column fixed, right side bar with header and footer page, css saved to external style sheets.
in the conditional page code you have
<!--[if lt IE 7]>
<style type="text/css">
img, div {
behavior: url("file:///D|/webs/tester/2ColumnFixedRightSidebarHeaderandFooter0_images/iepngfix.htc");
</style>
<![endif]-->
surely this should be
<!--[if lt IE 7]>
img, div {
behavior: url(2ColumnFixedRightSidebarHeaderandFooter0_images/iepngfix.htc);
</style>
<![endif]-->
Also is it safe for me to rename the folder from 2ColumnFixedRightSidebarHeaderandFooter0_images to something shorten and less clumsy
Roy
Folder names are not significant and can be updated.
The full file url is used by DW if you are working on a page that is not saved... it can't use the relative path since it doesn't know the location where the file will be eventually saved to.
It appears that because the code is in a comment, dreamweaver doesn't update the link properly as it would normally. This definitely could be considered a bug, but that is the description of the reason it occurs. We may be able to save the page earlier in the process to get around this problem.
