can't select Recordset Loop, it is grayed out
Thread begun 11/23/2010 1:03 pm by kevin389160 | Last modified 8/27/2015 12:31 pm by Ray Borduin | 6173 views | 15 replies |
kevin389160
What do I need to do to select Recordset Loop? It allows me to select Enter Value and From File but not Recordset Loop. Why? I have a recordset already setup, but it is just always grayed out. Please help.
can you send a copy of your page please.
kevin389160
This is a copy of the page that I trying to set the Recordset Loop on in CSS Form Builder 2. I wanting to set it on the (TO) field of the email form.
I uploaded a copy in a doc format called "email form.doc"
you're message does not have an attachment to it
Please add the php page to a zip archive and attach the zip file to the message.
sharon39426
I can't select recordset loop either
the field is greyed out. was this ever resolved? thanks.
sharon39426
Thanks I figured it out.
I had to create the whole behavior first, then go back and edit it for recordset looping. Worked fine.
jdjackson
My Recoredset Is Grayed Out
I can get the email to work for one record but not the entire record set. I am using DW CS6 and Create Email from Data Bridge.
I have attached my page.
Thanks for your help...John
That is because Universal Email isn't updated to work with MySQLi recordsets yet.
You can do it by manually adding code above the email but below the recordset to create an array like:
$colArray = array();
      for ($x=0; $x<sizeof($rsMSQLiEmailList->Results); $x++) {
        $colArray[] = $rsMSQLiEmailList->Results[$x]["ToEMail"];
Then update where it sets the recipients on line 27:
$RecipArray[$CurIndex ][] = "".((isset($_POST["ToEMail"]))?$_POST["ToEMail"]:"") ."";
to:
$RecipArray[$CurIndex ] = $colArray;
jdjackson
NEW ERROR
Must not have placed code in correct location. I have attached the error message and the page.
Thanks..John
