Name of image showing instead of Image
Thread begun 11/18/2010 3:46 pm by willo009412397 | Last modified 1/19/2011 7:17 am by Jason Byrnes | 6316 views | 11 replies |
willo009412397
Hi
Im using CS5 and trying to use Universal Email to aid file upload. But the problem i have is when showing on the `results page` where the image should be, it shows its file name where i want the image showing. Many thanks in advance of help.
Regards Karl
You need to add an image tag.
place your cursor where the image shlould display, then go to Insert -> Image.
Change the Select File Name From option to Data Sources.
From the bindings panel, select the image column from your recordset.
this will give you an image tag that looks like:
<img  src="<?php echo $row_RecordsetName['ColumnName']; ?>" />
you will need to add the image upload folder in front of this, for example, if images are uploaded to the image folder:
<img  src="image/<?php echo $row_RecordsetName['ColumnName']; ?>" />
willo009412397
Thankyou Mr Byrnes its working great, can i upload `video` using this? if so is the tag i use the same?. Thankyou for all your help, you always reply very fast
yes, you can upload video using digital file pro, but the tag to display it will be different depending on the type of video you are uploading.
some video types may require special plug-ins to be installed in the browser in order to display.
willo009412397
Only 1 image showing
Hi Jason
What you said above worked great, so a big thanks for that. However the problem i have now is theres only 1 image showing. When i do a search it finds the records, and displays the Details of them, but only the 1st Image is showing. The other records show just the details but no image. Please help.
please send a copy of your page in a zip archive so i can examine the code.
willo009412397
Sorry Jason its ok, the problem was the images that did not show in search. Are images that were uploaded before i did what you said above. It works fine, thankyou for your help.
Ok, glad to hear it is working.
willo009412397
Hi im having this problem again, thought i would continue this thread hope thats ok?. The images are uploading to the database but not showing on page. Also when i upload the images on my insert page i get this error
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\xampp\htdocs\Petseen\ShopAdmin\shop_Insert.php:20) in C:\xampp\htdocs\Petseen\webassist\file_manipulation\helperphp.php on line 70
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\Petseen\ShopAdmin\shop_Insert.php:20) in C:\xampp\htdocs\Petseen\ShopAdmin\shop_Insert.php on line 54
I have tried delete cache but has not worked, i have added the files for this for you too look at. Thanks for any helpon this.
Karl
the headers already sent error means there is output to the page between php tags. The error is reporting the problem around line 20:
output started at C:\xampp\htdocs\Petseen\ShopAdmin\shop_Insert.php: 20
at line 18 - 20, you have:
<?php?>
change that to:
on the results page, you need to convert the code that displays the file name to an image tag:
<td class="WADAResultsTableCell"><?php echo($row_WADAshop['productImageSource']); ?></td>
should be:
<td class="WADAResultsTableCell"><img  src="../Shopimages/<?php echo($row_WADAshop['productImageSource']); ?>" /></td>
