Recordset not showing up in the bindings panel?
Thread begun 11/17/2010 12:48 pm by ijk76319396 | Last modified 11/18/2010 10:48 am by Jason Byrnes | 2421 views | 2 replies |
ijk76319396
I have this recordset on my page which is functioning fine, however it doesn't appear in the recordset bindings panel. Is there an error or something in the code that is preventing it from doing so?
This is the code
mysql_select_db($database_con2com, $con2com);
$query_rsVOTES = "SELECT username, Sum(score) FROM points
GROUP BY username ORDER by Sum(score) DESC LIMIT 0,1";
$rsVOTES = mysql_query($query_rsVOTES, $con2com) or die(mysql_error());
$row_rsVOTES = mysql_fetch_assoc($rsVOTES);
$totalRows_rsVOTES = mysql_num_rows($rsVOTES);
I need it to show up because I am trying to run a repeat region too.
ijk76319396
For anyone who might have had this problem it was due to the 2nd string of code not being on the same line. Really weird and simple fix. I guess they all have to be on the same line. So the correct code looks like
$query_rsVOTES = "SELECT username, descrpt, title, website, userID, Sum(score) FROM points GROUP BY username ORDER BY Sum(score) DESC LIMIT 0,1";
Glad to hear you have solved the issue.
