Am I missing the point?
Thread begun 11/05/2010 12:53 pm by biesheuvel378713 | Last modified 11/05/2010 2:26 pm by Ray Borduin | 2454 views | 1 replies |
biesheuvel378713
I was reading in this forum that imageresizer also works on dynamic sites like PowerCMS and site sculptor sites.
Now I've been playing with a (test) site sculptor site I can't get it to work.
Whenever I select a part of the page where the dynamic text (with images) should be placed image resizer replaces al the code with the code for an empty image?
Thanks in advance
You are running into a bug... The solution is to apply the image resizer first, then replace the image with the content you are using, or to apply image resizer from the server behaviors window, which I believe will work correctly.
The logic is that if there is no image selected it tries to add an image... but when you have fully dynamic content that doesn't work so it is a bug. We will correct that in the next dot release.
